I am fine with the regular expression. However, the GUI filter chain tester should work otherwise configuration becomes complicated.
On Wed, Jun 17, 2015 at 6:57 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
I have almost finished adding query string matching to filter chains.
During the work I decided to change things a little bit in respect to the original plan.
Basically:
- I removed the flag for query string matching
- to specify query string matching, a regular expression needs to be added to an existing ANT pattern; I tried to use this syntax:
| where | is optional (if not specified the old matching behaviour is used). The pipe separator can be changed if anyone has different preferences.
An example of complete pattern:
/wms/**|.format=image/png.
I think using the full regular expression syntax for the query string matcher is better, since we have more expressive power, but we can also choose to implement a simpler syntax with only the * and ? wildcards accepted. Any thoughts?
Thanks
Mauro Bartolomeoli
2015-06-14 11:00 GMT+02:00 Christian Mueller <christian.mueller@anonymised.com>:
Hi Mauro
Sounds good to me, I had the same idea some time ago.
Is it possible for you to fix the bug with the filter chain tester.
Christian
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
On Fri, Jun 12, 2015 at 6:51 PM, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com.1268…> wrote:
following up https://osgeo-org.atlassian.net/browse/GEOS-7059 I think it would be useful to allow filter chains pattern matching to also work (optionally) on the query string (for example to have a different set of filters for different output formats, like in the JIRA example).
It should not be too difficult. My plan is to:
- add a new flag to RequestFilterChain (matchQueryString), defaulted to false
- extend Spring Security AntPathRequestMatcher to allow matching a request url that contains the query string (currently only path info is checked)
- use the extended AntPathRequestMatcher for chains where matchQueryString is true (in GeoServerSecurityFilterChainProxy)
- extend the Wicket UI with a checkbox for the new flag
Mauro Bartolomeoli
@mauro_bart
Geoserver-devel mailing list
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
