[Geoserver-devel] In-memory vs on-disk sorting
Will looking into some slow WFS paging/sorting results, I found that the hint MAX_MEMORY_SORT is both 1) really low (1000) and 2) not configurable from the commandline or GeoServer's UI.
Would anyone be fussed if we bumped the value from 1000? (Configured here: (1).) Would something like 100k be ok given that RAM is cheap?
Second, would it make sense for this option to be configured on GeoServer's Settings->Global page?
For my current need, I can use some of my own classes which are instantiated a GeoServer startup to call 'Hints.putSystemDefault(Hints.MAX_MEMORY_SORT, BIGGER_NUMBER)' manually....
Thanks in advance for any feedback,
Jim
1. https://github.com/geotools/geotools/blob/master/modules/library/main/src/main/java/org/geotools/data/sort/MergeSortDumper.java#L93
On Tue, May 10, 2016 at 12:15 AM, Jim Hughes <jnh5y@anonymised.com> wrote:
100k seems way too much indeed :-p
You'd be surprised by how many organisations here in Europe are running
GeoServer on 512MB
to 2GB of memory, I don't want to cut them out of the gates right away (the
advent of virtualization
around here in Italy and probably south Europe often meant that you get to
play in a VM that's
smaller than a real world notebook).
Also, consider the case you're serving large features, either because they
have a
significant geometry (try this
https://www.ngdc.noaa.gov/mgg/shorelines/gshhs.html )
or just because they are serving lots of concurrent requests.
Please do, that would accommodate both people having plenty of hardware,
and those
who don't.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
