We are facing some issue with overlay elements not completely drawn while moving the map. Elements are drawn again when user zooms out and then back in (problem with all browsers) Firefox debugging shows below error. XML Parsing Error: no root element found Location: http://127.0.0.1:8090/xxxxx/action?cmd=userAction&do=CheckUserValid Line Number 1, Column 1:
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hi there,
does not look like a GeoServer issue, the failing HTTP request do not seem part of the GeoServer services at all?
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea,
It is happening with all layers. Even I thought same but when drag map left and right, sometime missing images comes up but not all the time.
Did you face such issue ? Can you please try in your setup if something comes ?
Pradeep
Things should be made as simple as possible and not one bit simpler
Pradeed, this list is for people to discuss their changes to the geoserver own code.
Are you going to make pull requests related to this issue?
If not, please resume discussion on the geoserver-users list, there are more subscribers and maybe someone
saw the same issue you’re seeing.
