[Geoserver-devel] infinite loop using uom w/ GraphicStroke
I found an issue where the SDL renderer gets into an infinite loop when
using a GraphicStroke line simbolyzer with the uom extension. To
reproduce, consider the following SDL fragment:
<sld:LineSymbolizer uom="http://www.opengeospatial.org/se/units/metre&quot;&gt;
    <sld:Stroke>
        <sld:GraphicStroke>
            <sld:Graphic>
                <sld:Mark>
                  <sld:WellKnownName>shape://vertline</sld:WellKnownName>
                   <sld:Stroke>
                       <sld:CssParameter
name="stroke">#000000</sld:CssParameter>
                        <sld:CssParameter
name="stroke-width">1</sld:CssParameter>
                    </sld:Stroke>
                </sld:Mark>
                <sld:Size>12</sld:Size>
            </sld:Graphic>
        </sld:GraphicStroke>
        <sld:CssParameter name="stroke-dasharray">12 18</sld:CssParameter>
    </sld:Stroke>
</sld:LineSymbolizer>
when trying to render, say lines of an OSM database with the above,
geoserver gets into an infinite loop.
I looked at the code, and found the following, although I'm not sure how
to fix the issue. the infinite loop is this one, in StyledShapePainter,
starting at line 466:
for (dist = remainder; dist < len; dist += imageSize) {
    renderGraphicsStroke(graphics, x, y, graphicStroke, rotation, 1,
isLabelObstacle);
    x += dx;
    y += dy;
and the reason is that imageSize == 0, thus dist does not increase.
looking at the code, it turns out that imageSize comes from a
MarkStyle2D object's size attribute, which is 0. it is set to 0 in
SLDStyleFactory.createPointStyle(), line 647:
ms2d.setSize((int) size);
where this size value is set at line 542 in the same function:
size = evalToDouble(sldGraphic.getSize(), feature, 0);
now, the (double) size value is calculated to less than 1 (but still
greater than 0), and casting to int will turn it into 0.
I wonder what a proper fix to this issue would consist of? rounding up
size to 1?
Akos
On Tue, Aug 14, 2012 at 7:18 PM, Ákos Maróy <akos@anonymised.com> wrote:
<sld:LineSymbolizer uom=“http://www.opengeospatial.org/se/units/metre”>
sld:Stroke
sld:GraphicStroke
sld:Graphic
sld:Mark
sld:WellKnownNameshape://vertline</sld:WellKnownName>
sld:Stroke
<sld:CssParameter
name=“stroke”>#000000</sld:CssParameter>
<sld:CssParameter
name=“stroke-width”>1</sld:CssParameter>
</sld:Stroke>
</sld:Mark>
sld:Size12</sld:Size>
</sld:Graphic>
<sld:CssParameter name=“stroke-dasharray”>12 18</sld:CssParameter>
</sld:Stroke>
I looked at the code, and found the following, although I’m not sure how
isLabelObstacle);
x += dx;
y += dy;
MarkStyle2D object’s size attribute, which is 0. it is set to 0 in
size to 1?
Given that Java2D can handle float/double dimensions just fine I’d just
promote MarkStyle2D size to a double and fix the callers of setSize
accordintly
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
