In conjunction with the wms 1.3 work that is going on I would also like to add a new community module named “inspire”. The point of which is to add inspire specific metadata extensions to the wms capabilities document (wms extended capabilities stuff).
The idea is that the admin can edit some very basic fields through the ui and teh extension will augment the wms capabilities document. This involves the ExtendedCapabilitiesProvider extension point that is part of the core WMS 1.3 proposal.
In support of this however, another web extension point is also required to be able to allow a plugin to add panel extensions to the regular service admin pages. In this specific case the inspire module will add a new “INSPIRE” panel extension to allow the admin to fill out the metadata.
I created a jira issue for the extension point with a patch that lives here:
http://jira.codehaus.org/browse/GEOS-4261
It is pretty straight forward so i did not go so far as to create a GSIP for it. But i am happy to if people think one is required.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
On Thu, Dec 16, 2010 at 8:34 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
add a new community module named "inspire". The point of which is to add
WMS 1.3 proposal.
"INSPIRE" panel extension to allow the admin to fill out the metadata.
Works for me, no need for a GSIP imho
+1
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
+1. No need for a GSIP. The changes needed for this to work were
approved as part of GSIP-56.
Gabriel
> Hi all,
> WMS 1.3 proposal.
+1
Ing. Andrea Aime
fax: +39 0584962313
Lotusphere 2011
Register now for Lotusphere 2011 and learn how
to connect the dots, take your collaborative environment
to the next level, and enter the era of Social Business.
http://p.sf.net/sfu/lotusphere-d2d
Geoserver-devel mailing list
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
+1
On 17/12/10 03:34, Justin Deoliveira wrote:
In conjunction with the wms 1.3 work that is going on I would also like to add a new community module named "inspire". The point of which is to add inspire specific metadata extensions to the wms capabilities document (wms extended capabilities stuff).
In support of this however, another web extension point is also required to be able to allow a plugin to add panel extensions to the regular service admin pages. In this specific case the inspire module will add a new "INSPIRE" panel extension to allow the admin to fill out the metadata.
-Justin
Justin Deoliveira
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
