[Geoserver-devel] Installation/Running problem with GeoServer
Hi!
Could you please help with this problem.
I am running GeoServer in Fedora 8 Core with java 1.7 Tea. I have unzipped geoserver to usr/local, made neccesary enviroment variables(JAVA_HOME, GEOSERVER_HOME), but I get following error(geoserver is not working on localhost:8080):
GEOSERVER_HOME environment variable not found, using current
location. If not set then running this script from other
directories will not work in the future.
GEOSERVER DATA DIR is /usr/local/geoserver
2 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger
@1bca5f1 via org.mortbay.log.Slf4jLog
940 [main] INFO org.mortbay.log - jetty-6.0.2
5830 [main] ERROR org.mortbay.log - failed org.mortbay.jetty.webapp.WebAppContext@anonymised.com…{/geoserver,file:/usr/local/geoserver/webapps/geoserver/}
java.util.ServiceConfigurationError: javax.imageio.spi.ImageReaderSpi: Provider it.geosolutions.imageio.stream.input.spi.FileImageInputStreamExtImplSpi could not be instantiated: java.lang.ClassCastException: Cannot cast it.geosolutions.imageio.stream.input.spi.FileImageInputStreamExtImplSpi to javax.imageio.spi.ImageReaderSpi
at java.util.ServiceLoader.fail(ServiceLoader.java:225)
at java.util.ServiceLoader.access$100(ServiceLoader.java:182)
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:371)
at java.util.ServiceLoader$1.next(ServiceLoader.java:439)
at javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:211)
at javax.imageio.spi.IIORegistry.(IIORegistry.java:139)
at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:160)
at org.geotools.resources.image.ImageUtilities.allowNativeCodec(ImageUtilities.java:463)
at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:59)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:451)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:124)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1219)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:421)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:496)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:40)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:156)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:120)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:119)
at org.mortbay.jetty.Server.doStart(Server.java:228)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:929)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:623)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: java.lang.ClassCastException: Cannot cast it.geosolutions.imageio.stream.input.spi.FileImageInputStreamExtImplSpi to javax.imageio.spi.ImageReaderSpi
at java.lang.Class.cast(Class.java:3008)
at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:363)
… 28 more
5836 [main] ERROR org.mortbay.log - failed ContextHandlerCollection@12c9557
… 28 more
5960 [main] WARN org.mortbay.log - failed org.mortbay.jetty.NCSARequestLog@anonymised.com
java.io.IOException: Cannot write log directory /usr/local/geoserver/logs
at org.mortbay.util.RolloverFileOutputStream.setFile(RolloverFileOutputStream.java:131)
at org.mortbay.util.RolloverFileOutputStream.(RolloverFileOutputStream.java:88)
at org.mortbay.jetty.NCSARequestLog.doStart(NCSARequestLog.java:363)
at org.mortbay.jetty.handler.RequestLogHandler.doStart(RequestLogHandler.java:116)
5963 [main] WARN org.mortbay.log - failed RequestLogHandler@anonymised.com
5965 [main] WARN org.mortbay.log - failed HandlerCollection@anonymised.com
org.mortbay.util.MultiException[java.util.ServiceConfigurationError: javax.imageio.spi.ImageReaderSpi: Provider it.geosolutions.imageio.stream.input.spi.FileImageInputStreamExtImplSpi could not be instantiated: java.lang.ClassCastException: Cannot cast it.geosolutions.imageio.stream.input.spi.FileImageInputStreamExtImplSpi to javax.imageio.spi.ImageReaderSpi, java.io.IOException: Cannot write log directory /usr/local/geoserver/logs]
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
… 28 more
5980 [main] WARN org.mortbay.log - Error starting handlers
… 28 more
6089 [main] INFO org.mortbay.log - Started SelectChannelConnector @ 0.0.0.0:8080
Thanks, Ivan
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
