I finshed the geoserver tutorial for the feature-pregeneralizd module.
http://docs.geoserver.org/1.7.x/user/tutorials/feature-pregeneralized/featur e-pregeneralized_tutorial.html
(at the moment of writing this email, it is not up to date, but it is already commited)
For testing the tutorial, the gt-feature-pregneralizd-<version>.jar from geotools/plugin and the
feature-pregeneralized-<version>.jar from the geoserver community module must be in WEB-INF/lib.
What are the next steps ?
I guess the next logical step is to upgrade it to an extension as outlined here:
http://geoserver.org/display/GEOS/GSIP+22+-+Community+Modules
Basically:
1) moving the module
2) updating all the relevant pom.xml and profiles
3) add a release artifact descriptor for it
I believe you went through the process for imagemosaic-jdbc?
-Justin
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, & iPhoneDevCamp asthey present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://www.creativitycat.com _______________________________________________
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Yes, I did the the same thing with imagemosaic-jdbc which was completely taken from geotools.
The difference is that there are 2 modules
gt-feature-pregeneralized from geotools
feature-pregeneralized from geoserver
which are tied together.
Should I make 2 independent extensions ?. That could be confusing.
Justin Deoliveira writes:
Basically:
-Justin
http://docs.geoserver.org/1.7.x/user/tutorials/feature-pregeneralized/fea tur e-pregeneralized_tutorial.html
Justin Deoliveira
It should be pretty much identical. Since the feature-pregeneralized community module (soon to be an extension) declares a maven dependency on gt-feature-pregeneralized, it will get dragged in.
The only difference will be in the release/ext-feature-pregenerialized.xml release artifact descriptor. YOu just need to configure it to grab both of the jars.
Does that make sense. I am happy to help setting it up. I realize there are a couple of tricky steps.
-Justin
Basically:
-Justin
Justin Deoliveira
Justin Deoliveira
I checked in the move from communtiy module to extension module . My local hudson based on an ibm 6.0 jdk executes a build without errors.
Anyway, could you take a short look if anything is ok ?
-Justin
Basically:
-Justin
http://docs.geoserver.org/1.7.x/user/tutorials/feature-pregeneralized/f ea tur e-pregeneralized_tutorial.html
Justin Deoliveira
Justin Deoliveira
It all looks great. The only two very minor mods i had to make where:
1) Change the groupId to org.geoserver.extension in the pom.xml of feature-pregen
<version>1.7.5-SNAPSHOT</version>
</parent>
- <groupId>org.geoserver</groupId>
+ <groupId>org.geoserver.extension</groupId>
<artifactId>feature-pregeneralized</artifactId>
<packaging>jar</packaging>
2) Add an include entry to the artifact descriptor for the geoserver lib
<directory>release/target/dependency</directory>
<outputDirectory></outputDirectory>
<includes>
+ <include>feature-pregeneralized-*.jar</include>
<include>gt-feature-pregeneralized-*.jar</include>
</includes>
<excludes>
Great work
Aside, I guess we should add this to the list of extensions that need to be ported to trunk.
-Justin
-Justin
Yes, I did the the same thing with imagemosaic-jdbc which was completely taken from geotools. The difference is that there are 2 modules gt-feature-pregeneralized from geotools
feature-pregeneralized from geoserver which are tied together. Should I make 2 independent extensions ?. That could be confusing.
I guess the next logical step is to upgrade it to an extension as outlined here: http://geoserver.org/display/GEOS/GSIP+22+-+Community+Modules Basically: 1) moving the module
3) add a release artifact descriptor for it I believe you went through the process for imagemosaic-jdbc? -Justin Christian Müller wrote:
(at the moment of writing this email, it is not up to date, but it is already commited) For testing the tutorial, the gt-feature-pregneralizd-<version>.jar from geotools/plugin and the
feature-pregeneralized-<version>.jar from the geoserver community module must be in WEB-INF/lib. What are the next steps ? ----------------------------------------------------------------------- -- -----
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
Thanks, there are 3 extensions
1) imagemosaic-jdbc
2) feature-pregeneralized
3) jdbc-ng (especially jdbc-db2 in my case)
where I am involved.
I tried to port 1) und 2) to geoserver trunk and had some difficulties. Is it a better strategy to defer this ports and doing the whole stuff in a bunch ?
Anyway, I am very careful to have geotools 2.5.x and 2.6.x in a "synchronzied" state for the needed geotools jar files.
</parent>
<includes>
</includes>
<excludes>
Great work
-Justin
-Justin
http://docs.geoserver.org/1.7.x/user/tutorials/feature-pregeneralized /f ea tur e-pregeneralized_tutorial.html
feature-pregeneralized-<version>.jar from the geoserver community module must be in WEB-INF/lib. What are the next steps ? --------------------------------------------------------------------- -- -- -----
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
As you see fit. There is an open jira to port all extensions to trunk:
http://jira.codehaus.org/browse/GEOS-2887
Currently scheduled for beta2. Doing them in batch should work, however some may require some code changes to work on trunk. The restconfig extension definitely does.
-Justin
1) imagemosaic-jdbc
</parent>
<includes>
</includes>
<excludes>
Great work
-Justin
-Justin
feature-pregeneralized from geoserver which are tied together. Should I make 2 independent extensions ?. That could be confusing. Justin Deoliveira writes:
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
Justin Deoliveira
