[Geoserver-devel] IntelliJ users, how do you handle "Entity resolution disallowed for file:/home/aaime/devel/git-gt/modules/.../*.xsd"
I’m dabbling with IntelliJ lately and I have both GeoServer and GeoTools linked in the same big
IntelliJ project.
Works nice as I do a lot of cross project activity, this allows to just see the effect of changes done
in GT or JAI-Ext without having to rebuild stuff in the middle.
However I’m getting a lot of failures because the sources of XSD files are available via file:/ instead
of jar:/… (since projects are directly linked instead of going through the jar files), with traces like:
Caused by: org.xml.sax.SAXException: Entity resolution disallowed for file:/home/aaime/devel/git-gt/modules/extension/xsd/xsd-wps/target/classes/org/geotools/wps/wpsAll.xsd
at org.geotools.xml.PreventLocalEntityResolver.resolveEntity(PreventLocalEntityResolver.java:76)
at org.geotools.xml.PreventLocalEntityResolver.resolveEntity(PreventLocalEntityResolver.java:101)
at org.geotools.xml.impl.ParserHandler.resolveEntity(ParserHandler.java:289)
at com.sun.org.apache.xerces.internal.util.EntityResolver2Wrapper.resolveEntity(EntityResolver2Wrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.resolveEntity(XMLEntityManager.java:1081)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaLoader.resolveDocument(XMLSchemaLoader.java:657)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.findSchemaGrammar(XMLSchemaValidator.java:2430)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.handleStartElement(XMLSchemaValidator.java:1767)
at com.sun.org.apache.xerces.internal.impl.xs.XMLSchemaValidator.startElement(XMLSchemaValidator.java:740)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:374)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl$NSContentDriver.scanRootElementHook(XMLNSDocumentScannerImpl.java:613)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:3132)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:852)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:112)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
at org.geotools.xml.Parser.parse(Parser.java:253)
at org.geotools.xml.Parser.parse(Parser.java:201)
at org.geoserver.wps.xml.v1_0_0.WpsXmlReader.read(WpsXmlReader.java:51)
How are others handling this issue?
Would it make sense to allow entity resolution in test code, besides the few that do check the resolution prevention
mechanism?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I have the same issue in my big eclipse workspace with both GT and GS in it. I get around it currently by closing the XSD modules and letting eclipse pick the jars up but it would be much easier if in tests we allowed the use of file:// urls.
Ian
On 14 December 2017 at 13:35, Andrea Aime <andrea.aime@anonymised.com> wrote:
IntelliJ project.
mechanism?
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ian Turton
While I do use Intellij, I have GeoTools and GeoServer as separate projects, so I haven’t actually run into this.
Torben
Ian
IntelliJ project.
mechanism?
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel@anonymised.comrge.net
Ian Turton
Hi Ian,
well the system tests already do a few things that none would do in production, like having no security
besides a few test cases that wants to test it, so… I’ll try to cook up a patch for this too, to have
entity resolution enabled by default
Ian
IntelliJ project.
mechanism?
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Interesting, I stepped on a similar issue only with App-Schema integration tests.
On 12/16/2017 02:18 PM, Andrea Aime wrote:
Hi Ian,
Ian
On 14 December 2017 at 13:35, Andrea Aime <andrea.aime@…1268…> wrote:
IntelliJ project.
mechanism?
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Geoserver-devel@…756…rge.net
Ian Turton
Geoserver-devel@…366…sourceforge.net
Andrea Aime
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
for the record, pull request merged on master:
https://github.com/geoserver/geoserver/pull/2698
Thanks Brad for review and help in improving the code :slight_smile:
On Sat, Dec 16, 2017 at 3:18 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ian,
Ian
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
IntelliJ project.
mechanism?
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
