this morning I was playing with the windows installer stuff and I’ve noticed something
probably important: the 2.6-beta installer does not work due to permission issues
on my win7 vm, but if I build the installer using a recent NSIS, with the AccessControl
plugin, and following the instructions for the win-ng installer
(http://docs.geoserver.org/2.0.0/developer/release-guide/index.html#build-windows-installer-new)
then that works fine and I have full write access, using the scripts and materials
found here:
https://github.com/geoserver/geoserver/tree/master/src/release/installer/win
As noted in a separate thread, I indeed found some lines in the nsis installer
script that are apparently giving full write rights to the install folder.
I am wondering… may it be the case that maybe the windows build server generating the
windows installer is using a old version of nsis or a old version of the nsis script?
For reference, and for those that want to try it out, here is the windows installer
I’ve build following the old release instructions linked above:
https://dl.dropboxusercontent.com/u/2361103/geoserver-2.5-SNAPSHOT.exe
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
