[Geoserver-devel] Intermittent file deletion errors on ares Jenkins
We often get failures with these:
Tests run: 25, Failures: 0, Errors: 1, Skipped: 1, Time elapsed: 1.457 sec <<< FAILURE!
org.geoserver.wfs.v2_0.GetFeatureJoinTest Time elapsed: 56 sec <<< ERROR!
java.io.IOException: Unable to delete directory ./target/default6619173959064498977data.
Any idea what might be causing them?
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Hi Ben,
I have been wondering myself as well… normally *nix systems have no notion of locking
so a deletion on a local file system should not be disallowed.
However, I’ve seen it happen on NFS mounts for files that were being vi edited from
another terminal. That’s clearly not the case here, but wondering if maybe
there is a remote system mount and maybe there is a thread in the process
that failed to release a file somehow, or another process maybe scanning those
directories while the build runs?
Wondering if setting “testdata.force.delete=true” might help here?
https://github.com/geoserver/geoserver/blob/master/src/main/src/test/java/org/geoserver/data/test/SystemTestData.java#L1007
(assuming the failure to delete comes from there, that is…)
On Thu, Apr 27, 2017 at 6:18 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
sec <<< FAILURE!
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I just saw this locally in Eclipse while trying to run a GeoServer test method. No NFS, nothing else accessing this:
java.io.IOException: Unable to delete directory ./target/default6787978788767592945data.
  at org.apache.commons.io.FileUtils.deleteDirectory(FileUtils.java:1337)
  at org.geoserver.data.test.SystemTestData.tearDown(SystemTestData.java:1026)
  at org.geoserver.test.GeoServerBaseTestSupport.doTearDownClass(GeoServerBaseTestSupport.java:206)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:33)
  at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
  at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:678)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
  at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
On 27/04/17 19:42, Andrea Aime wrote:
Hi Ben,
I have been wondering myself as well... normally *nix systems have no
notion of locking
However, I've seen it happen on NFS mounts for files that were being vi
edited from
another terminal. That's clearly not the case here, but wondering if maybe
there is a remote system mount and _maybe_ there is a thread in the process
those
Wondering if setting "testdata.force.delete=true" might help here?
(assuming the failure to delete comes from there, that is...)
sec <<< FAILURE!
ERROR!
Kind regards,
Director
New Zealand
Check out the vibrant tech community on one of the world's most
Director
New Zealand
On Fri, Apr 28, 2017 at 5:37 AM, Ben Caradoc-Davies <ben@anonymised.com>
java:1337)
On a local system hum... what can it be? Maybe the directory is gone
already?
Ing. Andrea Aime
@geowolf
Technical Lead
java:1337)
already?
We could take the easy way out and change tearDown to use deleteQuietly but it would be nice to know the cause, especially after so much effort was invested in getting it to work on Windows.
Kind regards,
Director
New Zealand
java:1337)
already?
I think I have found the cause. GeoServerImpl is never disposed::
[GEOS-8122] Intermittent failure of FileUtils.deleteDirectory in SystemTestData.tearDown
https://osgeo-org.atlassian.net/browse/GEOS-8122
Kind regards,
Director
New Zealand
Pull request:
https://github.com/geoserver/geoserver/pull/2301
My next question is, was this defect the real cause of all those failures on Windows? Now that data stores are properly disposed, is the special handling for Windows in SystemTestData.tearDown() obsolete?
Kind regards,
Director
New Zealand
Hi Ben,
that’s awesome… I just need to ask, how did you get to the conclusion that those
two were the causes? :slight_smile: Did you managed somehow to reproduce locally?
On Wed, May 3, 2017 at 5:38 AM, Ben Caradoc-Davies <ben@anonymised.com191…> wrote:
Pull request:
Kind regards,
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Ah,
for Windows I believe we still need the extra checks as coverage files can still be stuck with a thread keeping them open for whatever reason (faulty test, bug in GeoServer teardown). Generally speaking, as we don’t have an active core developer on Windows and these stuff tends to be race condition related (“works on mine, fails on yours” types of stuff) I would not remove the Windows specific behavior.
On Wed, May 3, 2017 at 11:52 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Ben,
On Wed, May 3, 2017 at 5:38 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Pull request:
Kind regards,
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea,
I could not reproduce locally, but while trying to do so running org.geoserver.wfs.v2_0.GetFeatureJoinTest in Eclipse, I noticed that src/wfs/target/default7740998516718894422data/foo.2.log.db was being recreated after the data directory was deleted, which means that the H2 test database was not being disposed before the directory deletion. Although the application context is destroyed, breakpoints showed that CatalogImpl.dispose() and GeoServerImpl.dispose() are never called, so the H2 data store can go on writing logs. The only thing that will stop a directory from being deleted on Linux is if it is not empty, and this behaviour is a likely culprit. Adding a call to GeoServer.dispose() in GeoServerSystemTestSupport.destroyGeoServer() ensures that all data stores are disposed before the data directory is removed. This fix immediately stopped the writing of foo.2.log.db and data directories were fully cleaned up after GetFeatureJoinTest.
After applying the GeoServerSystemTestSupport.destroyGeoServer() fix, GWCIntegrationTest started failing deterministically in both Maven and Eclipse. Individual methods pass, but run as a suite, many failed, which is clear evidence of a leaky fixture. This test has TestSetupFrequency.REPEAT so we expect fresh beans in our Spring application context. The GWC bean (static singleton) was being reconstructed correctly, but the static tile encoder cache was hanging onto encoders: every test used encoders from whichever test class was first to use GWC.getResponseEncoder, and these could even be other test suites in the module as the static cache will persist once the class has been loaded. The stale encoders were revealed by the GeoServerSystemTestSupport.destroyGeoServer() fix, which ensured that the stale beans were disposed, breaking the leaky test. The fix was to make GWC.cachedTileEncoders a member rather than static, to ensure that each new GWC singleton gets a fresh cache.
The fixes are tiny: GEOS-8122 is a one-line fix that adds 33 characters, and GEOS-8123 is a one-line fix that removes 7 characters. These are dwarfed by the write-up. :slight_smile:
Kind regards,
Ben.
On 03/05/17 21:52, Andrea Aime wrote:
Hi Ben,
that's awesome... I just need to ask, how did you get to the conclusion
that those
Pull request:
Kind regards,
Director
New Zealand
Director
New Zealand
