On Fri, Jun 14, 2013 at 11:30 AM, Mauro Bartolomeoli <
mauro.bartolomeoli@anonymised.com> wrote:
Hi everybody,
I would like to add support for internationalized labels in
GetLegendGraphic output using the work done for GEOT-4477 and GEOT-4484.
To trigger a specific locale a new input to GetLegendGraphic will be
needed (named lang, or locale, which one do you like best?) Two options
here:
- adding a new LEGEND_OPTIONS parameter
- adding a new parameter directly to the request
INSPIRE provides guidance in this respect, any request that can be affected
by internationalization must support
a direct request parameter specifying the language, from the spec:
The name of this parameter shall be “LANGUAGE”. The parameter values are
based on ISO 639-2/B alpha 3 codes as used in [INS MDTG]
For example:
http://inspire.network.service.example/service?SERVICE=[...]&VERSION=[...]&LANGUAGE=eng
This is however for the capabilities request. For other operations the
guidance says:
For further language support for other operation it is
recommended to replace the operation-online-resources in each language
specific GetCapabilitiesResponse by a specific operation-online-resource
for that language. To support the additional
operation-online-resources the service shall listen at the language
specific operation end-points to
distinguish for the requested languages.
Which, imho, would be easily implemented if we allow the language to be a
KVP param in all requests,
so that code specifically interested in language issues can access it
either as part of the request object
(GetLegendGraphics case) or as a thread local.
Regardless of the specific solution I'd try to keep it uniform for all
services and methods, whilst legend_options
is specific to GetLegendGraphics.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
