I would like to introduce my colleague Martha.
Martha has been working on testing, automation and documentation in projects using GeoServer.
In the following months I’d like to have her help us perform the release trains, including the Nov. 18th one (for the first time, I’ll be there assisting her, and perform the GWC release).
As you know, to do that, she would need access to the build server, admin access to Jira, and probably commit access to the repositories. Would that be ok?
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
