[Geoserver-devel] Introduction for Paul Wittle
Hello,
Whilst I can no longer find the page that recommends this; I’m pretty sure I read somewhere that I should introduce myself if joining this particular mailing list so here goes.
My name is Paul Wittle and I currently work for Dorset County Council in the UK. I’m hoping to start learning how to do some basic development work for the GeoServer project.
I was discussing some things with Ian Turton earlier in the week and he suggested that I should join this mailing list so that is exactly what I have done.
Anyway, I’ll stop there as I’m not even sure if I’m still supposed to send the introduction email but I hope to be able to help with the project at some point soon once I’ve managed to work through the various training documents and navigated through the build issues involved as a rare Windows user.
Best Regards,
Paul Wittle
GIS Developer
County Hall
Dorchester
Dorset. DT1 1XJ
Tel: 01305 228473
E mail: p.wittle@anonymised.com
Welcome Paul,
Its always nice to hear from new GeoServer developers.
After you’ve managed to get the build working and such, a pull request adding a section or notes about how to get GeoServer building on Windows would be quite helpful. I’m sure whatever instructions we currently have for Windows Developers (if any) are quite out-of-date.
Torben
On Fri, Nov 24, 2017 at 8:17 AM, Paul Wittle via Geoserver-devel <geoserver-devel@lists.sourceforge.net> wrote:
Hello,
Best Regards,
Paul Wittle
GIS Developer
County Hall
Dorchester
Dorset. DT1 1XJ
Tel: 01305 228473
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Hi Paul,
good to have you.
We just got two changes to fix the GeoTools build on Windows, I don’t know what the GeoServer status is.
Once we have both building we can probably put back in shape the windows build server and re-enable the notifications:
http://winbuild.geo-solutions.it/jenkins/
Right now GeoTools is failing due to an old version of Maven and GeoServer due to lack of recent GeoTools jars, I’ve contacted Alessandro to see if we can get
that fixed.
Having you around would help tremendously in keeping the Windows build up, as sometimes it’s hard to figure out why the build fails there
without having a full dev env on Windows.
On Fri, Nov 24, 2017 at 5:17 PM, Paul Wittle via Geoserver-devel <geoserver-devel@lists.sourceforge.net> wrote:
Hello,
Best Regards,
Paul Wittle
GIS Developer
County Hall
Dorchester
Dorset. DT1 1XJ
Tel: 01305 228473
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks for both your replies I look forward to getting into things although as I say it might take me a while to get my head around all the systems I need to learn.
On the windows front I have just rebuilt an old laptop to run Ubuntu and I’m also working on my Windows 10 machine but I just discovered that even that can now run a Ubuntu subsystem with Bash. I don’t expect anyone else has played with that much if you are all using Linux as default but potentially I may not be so reliant on building it using ‘windows’ as such…although it might end up being more of a problem than a solution as who knows what errors there might be with Windows running Linux.
So far I have forked on Github (well updated the version I had; hopefully) and downloaded and built a version on both systems.
Windows did fail on the build but I just rebuilt it with my updated version (hopefully 2.12.1 master) and it was successful but I skipped the tests to save time so I’m guessing that doesn’t count.
The main errors I’m getting in Eclipse are to do with non-public API’s; should I be adding the exceptions for those or have I most likely missed a step?
Example line it doesn’t like:
import com.sun.org.apache.xml.internal.utils.XMLChar;
Sorry, that is probably the most basic new developer question you’ve had in a while but as I say I’m trying to push through the learning curve as quickly as I can.
Paul
Hi Paul,
good to have you.
that fixed.
Hello,
Best Regards,
Paul Wittle
GIS Developer
County Hall
Dorchester
Dorset. DT1 1XJ
Tel: 01305 228473
E mail: p.wittle@…4807…
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Hey Paul!
Yes that is a new feature for Eclipse, I have had to down grade that from error to warning to build the code in eclipse. We should update the developer guide with the hint.
It does point out a legitimate problem, perhaps we can discuss on a case-by-case basis.
On 28 November 2017 at 00:21, Paul Wittle via Geoserver-devel <geoserver-devel@anonymised.comet> wrote:
Paul
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: 25 November 2017 10:52
To: Paul Wittle <P.Wittle@anonymised.com>; Alessandro Parma <alessandro.parma@anonymised.com.solutions.it>
Cc: geoserver-devel@anonymised.comsourceforge.net
Subject: Re: [Geoserver-devel] Introduction for Paul Wittle
Hi Paul,
good to have you.
that fixed.
On Fri, Nov 24, 2017 at 5:17 PM, Paul Wittle via Geoserver-devel <geoserver-devel@anonymised.comsourceforge.net> wrote:
Hello,
Best Regards,
Paul Wittle
GIS Developer
County Hall
Dorchester
Dorset. DT1 1XJ
Tel: 01305 228473
Geoserver-devel@anonymised.comsourceforge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Jody Garnett
Hi Jody,
Did you want me to send through a list of all the errors I’m getting (I think it is only three or four references) so we can check them against the ones you are expecting? That way we can confirm that they all need downgrading to warnings.
I did get some other errors creep in after I updated it but realistically I’m just not spending enough time on the development yet; I’m still getting work to confirm that I can officially work on the project during work hours. I expect to confirm that today I hope.
As I say, I’m still relativity new to Github, Maven and Eclipse so it is quite a learning curve. The team I work in use SVN, MVC and Visual Studio so the systems are different enough for me to second guess myself on each step but I’ll speed up as time goes by.
Paul
Hey Paul!
Jody Garnett
On 28 November 2017 at 00:21, Paul Wittle via Geoserver-devel <geoserver-devel@lists.sourceforge.net> wrote:
Paul
From: andrea.aime@…403… [mailto:andrea.aime@…403…] On Behalf Of Andrea Aime
To: Paul Wittle <P.Wittle@…4807…>; Alessandro Parma <alessandro.parma@…1268…>
Cc: geoserver-devel@lists.sourceforge.net
Hi Paul,
good to have you.
that fixed.
Hello,
Best Regards,
Paul Wittle
GIS Developer
County Hall
Dorchester
Dorset. DT1 1XJ
Tel: 01305 228473
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
