[Geoserver-devel] Is GWC Documentation stuck at 1.15.2?
Hi lists,
sorry for cross-posting.
I have noticed that the Geowebcache documentation is still pointing/reporting 1.15.2
https://www.geowebcache.org/docs/current/index.html
Any plan to have it updated to a more recent version?
Asking that since I would like to contribute some doc updates.
Best Regards,
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I think we may be stuck on domain transfer to OSGeo or something, I am not sure how to update the documentation presently.
Torben or Tom may know more…
Jody
Jody Garnett
For GeoWebCache, from what I recall, updating the documentation is a manual step that is done as part of the release process. However, the documentation on doing so seems to have disappeared. It should still be possible to update the docs - as far as I know, they are stored on the same system as the GeoServer documentation, which is still getting updated regularly (but has the advantage of being an automatic process), but if no one is actually doing it then it’s not going to happen.
That’s about all the information I’ve got.
Torben
On Wed, Apr 14, 2021 at 8:56 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
On Tue, Apr 13, 2021 at 2:28 AM Daniele Romagnoli <daniele.romagnoli@anonymised.com…1268…> wrote:
Hi lists,
Best Regards,
Daniele Romagnoli
Geowebcache-devel mailing list
Geowebcache-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geowebcache-devel
Jody Garnett
Geoserver-devel mailing list
