Dear List,
I’m trying to use extensively isolated workspace and I’ve found a possible issue which I’m going to share with you before we open a ticket:
Steps:
Use geoserver 2.17.0
create an isolated workspace
add a jndi store
load a layer (I’m using gadm level0)
install VectorTyle extension
enable the vector tyle ‘format’ over that layer
I’m not able to see the:
https://xxxxxxxxxx/xxxxx/gwc/service/tms/1.0.0
trying to retrieve that or other requests I got errors like:
DEBUG [util.ResponseUtils] - Could not locate a layer or layer group with id LayerInfoImpl-3bba14cf:1711882e14e:-11bb within GeoServer configuration, the GWC configuration seems to be out of synch
2020-04-29 16:37:14,813 ERROR [geowebcache.GeoWebCacheDispatcher] - Request failed
java.lang.IllegalStateException: Could not locate a layer or layer group with id LayerInfoImpl-3bba14cf:1711882e14e:-11bb within GeoServer configuration, the GWC configuration seems to be out of synch
at org.geoserver.gwc.layer.GeoServerTileLayer.lambda$getPublishedInfo$0(GeoServerTileLayer.java:396)
at java.base/java.util.concurrent.atomic.AtomicReference.accumulateAndGet(AtomicReference.java:263)
at org.geoserver.gwc.layer.GeoServerTileLayer.getPublishedInfo(GeoServerTileLayer.java:386)
at org.geoserver.gwc.layer.GeoServerTileLayer.isEnabled(GeoServerTileLayer.java:307)
at org.geowebcache.service.tms.TMSDocumentFactory.getTileMapServiceDoc(TMSDocumentFactory.java:138)
at org.geowebcache.service.tms.TMSService.handleRequest(TMSService.java:251)
at org.geowebcache.service.tms.TMSService$$FastClassBySpringCGLIB$$34b3521.invoke()
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218)
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:750)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.geoserver.gwc.config.GWCServiceEnablementInterceptor.invoke(GWCServiceEnablementInterceptor.java:58)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:689)
at org.geowebcache.service.tms.TMSService$$EnhancerBySpringCGLIB$$136fc4fa.handleRequest()
at org.geowebcache.GeoWebCacheDispatcher.handleServiceRequest(GeoWebCacheDispatcher.java:406)
at org.geowebcache.GeoWebCacheDispatcher.handleRequestInternal(GeoWebCacheDispatcher.java:268)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.geoserver.gwc.dispatch.GwcServiceProxy.dispatch(GwcServiceProxy.java:80)
at jdk.internal.reflect.GeneratedMethodAccessor853.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
Note that I’ve also deleted that file multiple times recreating it with the UI with no success.
It started working once workspace isolation has been disabled.
Could you confirm? May I need to open a ticket?
Thanks
C.
Mr. Carlo Cancellieri
skype: ccancellieri
Twitter: @cancellieric
LinkedIn: http://it.linkedin.com/in/ccancellieri/
