A few months ago I started a thread [1] about allowing the definition of several workspaces with the same namespace in GeoServer.
The main (root) use case for this is to allow the publishing of the same complex feature type in GeoServer multiple times in different
workspaces. I finally had time to restart this work and can now give a more concrete answers to some of the comments.
The workspace and namespaces relationship boils down to how things are grouped together and stored in GeoServer catalog and the
ability to retrieve them. Let’s say that we have an arbitrary resource in GeoServer (layer, style, feature type, etc …), that resource
can be retrieved like this:
- getResourceByName(“layer1”, ResourceType.class)
- getResourceByName(“workspace:layer1”, ResourceType.class)
- getResourceByName(“{http:\www.workspace.com}:layer1”, ResourceType.class)
The three ways above (there is more ways of doing this) are all valid ways of referencing the same resource. The workspace name
and the workspace namespace are used interchangeably, this works fine because there is a one to one relationship between them.
Some business code tend to use the workspace name, and other code like WFS tend to use the namespace to reference a catalog
resource.
The concept of isolated workspaces (or namespaces) allow us to define multiple workspaces with the same namespaces. The
resources of an isolated workspace can only be accessed in the context of the virtual service of that workspace. Consider that
we have two workspaces with the same namespace:
- Prefix: ws1, URI: http://www.gs.com, Isolated: false
- Prefix: ws2, URI: http://www.gs.com, Isolated: true
And consider also that both workspaces have a feature type name complex_feature. In the catalog point of view all this invocations
will return the feature_type belonging to first workspace:
- getResourceByName(“complex_feature”, FeatureType.class)
- getResourceByName(“ws1:complex_feature”, FeatureType.class)
- getResourceByName(“{http://www.gs.com}:complex_feature”, FeatureType.class)
Only this invocation will retrieve the feature type belonging to the isolated workspace (second one):
- getResourceByName(“ws2:complex_feature”, FeatureType.class)
If a resource is identified by its namespace URI the catalog will never be able to find that resource if it belongs to an isolated
workspace, since the same namespace may be used by another workspace. That’s why we can only retrieve the content of an
isolated workspace from is virtual service, because if we are in the context of a certain virtual service we can automatically
convert the namespace URI in a specific workspace name \ prefix.
The catalog machinery is quite complex [1] with several wrappers and different catalog facades. To support workspaces isolation
we had to bring the concept of workspace isolation to the catalog facade implementations and implement the necessary handling
in the local catalog wrapper.
The changes in the facade are really simple, only one line of code was changed in DefaultCatalogFacadeImpl, we just need to make
sure that when we search a NameSpaceInfo by its URI namespaces that are tied to an isolated workspace are ignored. The issue is that
if a particular catalog facade implementation doesn’t do this change isolated workspaces are not correctly supported.
To avoid backward compatibility issues I introduced the concept of CatalogCapabilities (similar to Query capabilities in GeoTools), unless
a catalog facade or catalog implementation says explicitly that isolated workspaces are supported this functionality will be disabled. This
can be reused to support the introduction of new catalog features and avoiding breaking existing implementations.
The changes to support isolated workspaces are isolated int he catalog machinery and transparent to all the other business code. This
is backward compatible and will not break existing implementations, of curse if someone is using its own catalog facade implementation
isolated workspace will be disabled unless they implement the required business code.
I have made some preliminary tests with WMS and WFS operations and everything seems to be working as expected.
I hope this clarifies some of the doubts \ questions that were asked before.
[1] http://osgeo-org.1560.x6.nabble.com/Allowing-multiple-workspaces-to-use-the-same-name-space-URI-td5307302.html
[2] https://docs.google.com/drawings/d/1AvCBi4yyJQ60cCKcxSJkThom0tT9Epna8-mL31zS7Mo/edit?usp=sharing
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
