[Geoserver-devel] Issues running JDBCResourceStore
I’m running into some issues trying out the new JDBCResourceStore module. Running in my dev environment via Start.java is fine, the JDBC resource store gets initialized and imported, and I can see resources (such as Styles) being saved in the database; however, I run into issues running in a WAR environment on Tomcat.
Hooking up the debugger and watching the startup, it seems that the resource store beans are being initialized correctly except for the actual resourceStore itself defined here:
https://github.com/geoserver/geoserver/blob/master/src/community/jdbcstore/src/main/resources/applicationContext.xml#L37
I’m not a Spring expert, but from what I’ve read the issue seems to be overriding Spring beans by creating a duplicate with the same id doesn’t always produce consistent results. Whichever bean gets loaded first ends up getting used, so in my WAR deployment the original resourceStore defined in the main applicationContext.xml gets used:
https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/applicationContext.xml#L26
So that despite the fact that the jdbcstore module is enabled the original data dir based resource store ends up getting used.
Am I maybe missing something? Has anyone tried this in a WAR deploy yet? I don’t think duplicating a bean like that is great practice according to Spring docs. It looks like in the case of JDBCConfig a proxy class is used to load an implementation via Spring and fall back on a default one if none is found like this:
https://github.com/geoserver/geoserver/blob/a74a76d9c4bab0ef3bb8ea3a13f7abcabb3713d4/src/main/src/main/java/org/geoserver/config/GeoServerLoaderProxy.java#L75
I tried implementing a similar approach for the ResourceStore, but it’s complicated by the fact that GeoServerResourceLoader is itself an implementation of ResourceStore and already define in the main applicationContext.xml. I also looked at monkeying around with things using the Spring Primary/Autowire functionality, but this is hampered by the XML config API being slightly different than the annotations based config and I didn’t get very far.
Anyone have any thoughts? Is there something more basic I’m missing?
Devon
Jody Garnett
On 15 February 2016 at 16:40, Devon Tucker <devonrtucker@anonymised.com> wrote:
I tried implementing a similar approach for the ResourceStore, but it's
didn't get very far.
Sorry about that, made it implement the interface to make migrating client
code easier.
Anyone have any thoughts? Is there something more basic I'm missing?
The auto migration from file to jdbc makes this more complicated then
strictly necessary. If not for this feature we could make a war that only
had the JDBCResourceStore implementation.
Does spring have a priority we could use to control extensions? Or we could
bust out a -D command line option (to tell the proxy what to use? - with
the default being the file based implementation).
On Tue, Feb 16, 2016 at 2:31 AM, Jody Garnett <jody.garnett@anonymised.com>
could bust out a -D command line option (to tell the proxy what to use? -
with the default being the file based implementation).
I'm not aware of a bean priority that can be use for override in Spring.
The existing approach in all GeoServer for this cases is to have a default
implementation created programmatically unless
a different one can be found using a scan of the application context.
See how the ResourceAccessManager is looked up in SecureCatalogImpl, or
check how the catalog facade is setup with jdbc config
(the two approaches are different, both vaild).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Yeah, as he explained that is complicated by the fact that GeoServerDataDirectory and GeoServerResourceLoader are also resource store, but never "the" resource store (in fact, they depend upon it).
Solution #1
Use of a Spring "alias". An alias as higher priority than a normal name. However that only gives two levels of priority, once you have more than one alias you end up with the same issue. This may be sufficient for us though, assuming that we'd never need more than one custom ResourceStore in our context.
Solution #2
The pattern we used for geofence/geofence-server: using PropertyConfigurers we have full flexibility over priority. It would go something like this. In main applicationContext:
<bean id="resourcestore-configurer" class="org.geoserver.config.GeoServerPropertyConfigurer">
|*<property name="order" value="5"/>*
         <property name="properties">
             <props>
                 <prop key="theResourceStore">dataDirectoryResourceStore</prop>
             </props>
         </property>
</bean>
  <bean id="resourceStore" class="org.geoserver.platform.resource.ResourceStoreProxy">
         <property name="delegate" ref="$theResourceStore"/>
  </bean>
Then in the jdbcstore applicationContext:
        *<property name="order" value="4"/>*
             <props>
                 <prop key="theResourceStore">jdbcResourceStore</prop>
             </props>
        </property>
</bean>
Quite an elegant solution, if you ask me.
Kind Regards
Niels
On 16-02-16 09:27, Andrea Aime wrote:
On Tue, Feb 16, 2016 at 2:31 AM, Jody Garnett <jody.garnett@anonymised.com <mailto:jody.garnett@anonymised.com>> wrote:
        missing?
    then strictly necessary. If not for this feature we could make a
    war that only had the JDBCResourceStore implementation.
    we could bust out a -D command line option (to tell the proxy what
    to use? - with the default being the file based implementation).
The existing approach in all GeoServer for this cases is to have a default implementation created programmatically unless
See how the ResourceAccessManager is looked up in SecureCatalogImpl, or check how the catalog facade is setup with jdbc config
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-devel mailing list
The alias solution seems to work fine and is alright by me. I created a PR for it:
https://github.com/geoserver/geoserver/pull/1495
On Tue, Feb 16, 2016 at 1:10 AM, Niels Charlier <niels@anonymised.com> wrote:
Yeah, as he explained that is complicated by the fact that GeoServerDataDirectory and GeoServerResourceLoader are also resource store, but never “the” resource store (in fact, they depend upon it).
Solution #1
Use of a Spring “alias”. An alias as higher priority than a normal name. However that only gives two levels of priority, once you have more than one alias you end up with the same issue. This may be sufficient for us though, assuming that we’d never need more than one custom ResourceStore in our context.
Solution #2
|       **<property name="order" value="5"/>**
            <props>
            </props>
        </property>
</bean>
 </bean>
       **<property name="order" value="4"/>**
            <props>
            </props>
       </property>
</bean>
Kind Regards
Niels
[http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140](http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
On Tue, Feb 16, 2016 at 2:31 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I’m not aware of a bean priority that can be use for override in Spring.
Ing. Andrea Aime
@geowolf
Technical Lead
The auto migration from file to jdbc makes this more complicated then strictly necessary. If not for this feature we could make a war that only had the JDBCResourceStore implementation.
Does spring have a priority we could use to control extensions? Or we could bust out a -D command line option (to tell the proxy what to use? - with the default being the file based implementation).
Discussing with Devon here, would like to look at fixing the proxy tomorrow. The alias can be a backup plan - I will make a comment on the pull request.
On 16 February 2016 at 15:57, Devon Tucker <devonrtucker@anonymised.com> wrote:
Jody Garnett
Solution #1
Solution #2
            <props>
            </props>
        </property>
</bean>
 </bean>
            <props>
            </props>
       </property>
</bean>
Kind Regards
Niels
Ing. Andrea Aime
@geowolf
Technical Lead
Took a stab at doing a more comprehensive fix for this issue:
https://github.com/geoserver/geoserver/pull/1510
  • ResourceStoreProxy is now ResourceStoreFactory. Factory first searches for a “resourceStoreImpl” bean before falling back to the data directory implementation. I’m not personally fond of the name “resourceStoreImpl”, but I was kind of stuck because it needs to be something generic.
  • Removed ResourceStore interface from GeoServerSecurityManager, I don’t think it makes sense for this class to be a store and it wasn’t really being used that way anyway.
  • Removed ResourceStore interface from GeoServerDataDirectory where it wasn’t really being used. I got the impression from Jody that this whole class might be heading towards deprecation anyway (correct me if I’m wrong). There are a lot of deprecated methods in it.
Please take a look and let me know if there are any issues.
On Tue, Feb 16, 2016 at 4:26 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Solution #1
Solution #2
            <props>
            </props>
        </property>
</bean>
 </bean>
            <props>
            </props>
       </property>
</bean>
Kind Regards
Niels
Ing. Andrea Aime
@geowolf
Technical Lead
Some comments supplied for 510.
I was hoping that by implementing ResourceStore it would be easier for code to make the transition from File use to Resource use.
I believe that was the case, and Niels has done a lot of the transition in the last year. With the transition complete GeoServerDataDirectory indeed be offering reduced functionality.
Jody Garnett
Solution #1
Solution #2
            <props>
            </props>
        </property>
</bean>
 </bean>
            <props>
            </props>
       </property>
</bean>
Kind Regards
Niels
Ing. Andrea Aime
@geowolf
Technical Lead
The remaining logic could be moved to GeoServerResourceLoader. I don’t see a reason to have two middle men. Regards Niels
Looks fine to me.
Regards
Niels
On 23-02-16 00:35, Devon Tucker wrote:
- ResourceStoreProxy is now ResourceStoreFactory. Factory first searches for a "resourceStoreImpl" bean before falling back to the data directory implementation. I'm not personally fond of the name "resourceStoreImpl", but I was kind of stuck because it needs to be something generic.
- Removed ResourceStore interface from GeoServerSecurityManager, I don't think it makes sense for this class to be a store and it wasn't really being used that way anyway.
- Removed ResourceStore interface from GeoServerDataDirectory where it wasn't really being used. I got the impression from Jody that this whole class might be heading towards deprecation anyway (correct me if I'm wrong). There are a lot of deprecated methods in it.
On Tue, Feb 16, 2016 at 4:26 PM, Jody Garnett <jody.garnett@anonymised.com <mailto:jody.garnett@anonymised.com>> wrote:
    Jody Garnett
            Solution #1
            Solution #2
            applicationContext:
            |*<property name="order" value="5"/>*
                         <props>
                         </props>
                     </property>
            </bean>
              </bean>
                         <props>
                         </props>
                    </property>
            </bean>
            Kind Regards
            Niels
                    basic I'm missing?
            override in Spring.
            unless
            Ing. Andrea Aime
            @geowolf
            Technical Lead
            phone: +39 0584 962313 <tel:%2B39%200584%20962313>
            fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
            mob: +39 339 8844549 <tel:%2B39%20%C2%A0339%208844549>
            Le informazioni contenute in questo messaggio di posta
            elettronica e/o nel/i file/s allegato/i sono da
            considerarsi strettamente riservate. Il loro utilizzo è
            riceviate questo messaggio senza esserne il destinatario,
            Vi preghiamo cortesemente di darcene notizia via e-mail e
            di procedere alla distruzione del messaggio stesso,
            stesso, divulgarlo anche in parte, distribuirlo ad altri
            soggetti, copiarlo, od utilizzarlo per finalità diverse,
            costituisce comportamento contrario ai principi dettati
            dal D.Lgs. 196/2003.
            <mailto:Geoserver-devel@lists.sourceforge.net>
            Performance
            $35/Month
            actions now
            Signup Now!
        Performance
        actions now
On Tue, Feb 23, 2016 at 10:04 AM, Niels Charlier <niels@anonymised.com> wrote:
The remaining logic could be moved to GeoServerResourceLoader. I don't see
I have to ask, the beta release should have been cut 5 days ago, how much
instability this
late change (or to be precise, change past the deadline) is going to add?
Ing. Andrea Aime
@geowolf
Technical Lead
Agreed, we have several classes that have been responsible for the same story - gathering these methods into GeoServerResourceLoader is where I want to go as well.
One great thing the work you have done (and Devon’s change here) is code can be consistently injected with “resourceStore” bean and they will get the correct/configured implementation. So we should be able to reduce GeoServerResourceLoader still further (down to the few bits of code that need to look up a log file or a shapefile on disk.)
Regards
Niels
Jody Garnett
We can discuss at today’s meeting.
On 23 February 2016 at 01:13, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
I have to ask, the beta release should have been cut 5 days ago, how much instability this
Ing. Andrea Aime
@geowolf
Technical Lead
