Great ! Thanks or the feedback.
Note, when using JMS plugin data directory should not be shared
between GeoServer instances.
On 08/04/2017 05:17 PM, Corina Tudorache via Geoserver-devel wrote:
Hi Nuno,
I followed the guide lines from here
(http://geoserver.geo-solutions.it/educational/en/clustering/load_balancing/tomcat.html
and
http://geoserver.geo-solutions.it/educational/en/clustering/clustering/active/usage.html)
to create a cluster of GeoServer both instances sharing a common data
folder. I installed the geoserver-2.10-SNAPSHOT-jms-cluster-plugin.zip Next
I would like to use the geoserver-2.10-SNAPSHOT-activeMQ-broker-plugin.zip
My problem was that I didn't know where to create the setevn.sh file. But I
managed to figured it out.
Thank you for the response.
Kind regards,
Corina
View this message in context: http://osgeo-org.1560.x6.nabble.com/Issues-setting-the-DGEOSERVER-CONFIG-DIR-tp5329882p5330499.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Check out the vibrant tech community on one of the world's most
Geoserver-devel mailing list
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
