[Geoserver-devel] issues with 1.7.3
Running the wfs 1.1 cite tests popped out some issues with the bug fix for GEOS-2583, which outputs bounds for wfs 1.1 feature collections, and respects the service "featureBounding" configuration.
The issues (of course) pops up in corner cases, such as encoding feature collections which have no geometric attributes, and empty feature collections. The first is a bug in the construction of simple feature types. Filed here:
http://jira.codehaus.org/browse/GEOT-2373
The fix is more or less trivial, but to do it cleanly requires a change to a geoapi interface :frowning: Which then requires us to do another geoapi milestone release, etc... I could hack around the problem and instantiate the SimpleFeatureTypeImpl directly... but I can see people having an issue with this, including myself.
The issue of empty feature collection is an issue with one of the gml bindings, and is easily fixed.
So options on how to proceed:
1) do the right thing, fix the bug in geotools, update geoapi and push back the release a few days
2) roll back the fix for GEOS-2583, and live with the bug until the next release.
3) hack around the problem for now in geotools, and "promise" to fix it correctly for 1.7.4.
Thoughts? I personally am ok with pushing back the release a few days to do the fix properly. Serves us right for trying to fix bugs at the last minute ;).
Justin Deoliveira
OpenGeo - http://opengeo.org
Ok... reading through the javadocs of the geoapi feature model it appears that geotools is doing the correct thing. FeatureType.getCRS() is derived from the default geometric attribute of the type. In this case there is none, so null is acceptable.. nasty.
So I guess we will have to work around this case in geoserver, and in the case of no crs reported look it up from feature type info metadata. Not ideal but doable. I guess the bright side is that we won't have to go through the hassle of creating a geoapi release.
-Justin
Justin Deoliveira wrote:
Justin Deoliveira
It was not clear to me from this bug report what change to geoapi is needed.
Justin the timing is not bad on the geoapi side; I would like to make a GeoAPI 2.2.0 anyways (so we can close off that branch with GeoTools 2.5.x as its only user). I am doing a bunch of hacking this weekend with Mark and would be willing to apply the patch and make a new GeoAPI release for your Monday.
If this is an option; the timing for a geoapi release is good; I will check on IRC if you are around to talk this over.
Jody
I see - if it is nasty perhaps the javadocs can be changed. I did suspect that we added that method as short cut to asking people to check the default geometry all the time? The gml model allows for a SRSName to be defined at any level regardless of if a geometry is actually used.
See above; one will be needed anyways - but this way there is no time pressure.
Jody
The changes are pretty simple. Basically:
1) Change the javadoc of FeatureType a little bit, basically making the crs a first class property, and deriving it in cases where it is unset.
2) modify FeatureTypeFactory.createFeatureType() and createSimpleFeatureType() to take a CRS object.
I could go for this, but it involves getting people to agree that this is a worthy change. It sounds like we agree that it is.
I won't be around for most of today, and then I will be traveling over the weekend. I will give you my +1, but I would like to get approval from others like Andrea, Ben, Gabriel, etc... before proceeding.
Jody
Justin Deoliveira
Justin Deoliveira ha scritto:
This is my fault, and I'm totally ok to just revert the change that
triggered this issue (and I'm sorry for wasting your time on this)
(so I'd choose "pill" number 2).
However, I'm a little confused by the whole issue. When no
geometric attributes are extracted and feature bounding
is requested nevertheless, GetFeature does two things:
* it puts the geometry attributes in the list of attributes
   that have to be extracted anyways
* wraps the the returned feature collection with a
   FeatureBoundsFeatureCollection that will return only
   the requested attributes, but will leverage the raw
   feature collection to compute the collection bounds and
   the single feature bounds
Soo... all of the above should not be happening?
What's going on?
Andrea Aime
Not sure exactly, i would have to debug again to be sure what is happening. But at some point the CRS is lost. The envelope returned by FCFB.getBounds() has no CRS set on it. Perhaps this is the main issue and could be patched in FCFB directly. And asking the FCFB.getSchema() (which unless i am mistaken is the "view" of the actual type) for its CRS results in the issue I described above.
What's going on?
Justin Deoliveira
Ok. FCFB returns the "target", geometryless feature type, but has a reference to the native feature type inside. So I believe this
can be patched by having FCFB extract the CRS from its wrapped
feature collection schema and rebuilding the RereferenceEnvelope
with it before getBounds() returns (call it an educated guess,
I did not actually try).
Andrea Aime
Sounds good to me. The current "workaround" in FeatureCollectionTypeBinding is probably still a good idea imho, leaving it in as a defense mechanism can't hurt. Want to open a jira issue for 1.7.4?
Justin Deoliveira
http://jira.codehaus.org/browse/GEOS-2701
Andrea Aime
