The cite-wcs-1.0 job on Jenkins has been looking a little unstable lately.
It was failing for a couple weeks starting Feb 8.
Most recently, its failing to finish - I’ve had to manually cancel a couple jobs that had been running for 2+ hours (normally it completes in less than 10 minutes).
I’ve observed the same behaviour from the 2.15-cite-wcs-1.0 job, but not from any of the older jobs.
Is anyone aware of any recent changes that may have caused this sort of issue?
Torben
That was due to a configuration change in the jetty properties, I have commented about it in another thread (was a really bizarre one).
Nothing pops to mind (I had a quick look at the recent commit history without getting any bright idea…)
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
