[Geoserver-devel] Issues with GeoServer 2.0-RC1
in the last few days I played a bit with GeoServer 2.0-RC1 and find several issues.
I’m going to list them here since actually I don’t know if are known issues or they need a specific JIRA, I will wait for feedbacks on this.
  1. It’s not possible to update the WMS metadata configuration at all form the UI cause of a wired error saying “The following codes are not known to the EPSG authority: ” … the error disappears if I put at least one SRS ID on the Limited SRS list textbox
  2. The WFS-T does not work anymore using a client like uDig while it seems to work fine issueing the requests directly
  3. Though it’s possible to modify a Style of one of the layers on a layergroup by unchecking it, once the layer is re-enabled again the default style is grabbed back again
  4. The WMS GetFeatureInfo templates seem to not work anymore, or at least to update them anymore.
More issues soon … :slight_smile:
Alessio.
Eng. Alessio Fabiani
Founder / CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584 980933
fax: +39 0584 983027
mob: +39 349 8227000
http://geo-solutions.blogspot.com
Alessio Fabiani ha scritto:
Many issues have been found already and fixed, it's advisable to test
a nightly instead or RC1
I'm going to list them here since actually I don't know if are known issues or they need a specific JIRA, I will wait for feedbacks on this.
1. It's not possible to update the WMS metadata configuration at all form the UI cause of a wired error saying "The following codes are not known to the EPSG authority: " ... the error disappears if I put at least one SRS ID on the Limited SRS list textbox
Already fixed
This is new, which version of uDig?
3. Though it's possible to modify a Style of one of the layers on a layergroup by unchecking it, once the layer is re-enabled again the default style is grabbed back again
Can you first check with a nightly and then provide a step by step
report if the issue persists? For example it's not clear what you
mean by "layer re-enabled again".
The templates have to be placed in a different folder now as far
as I know, that is, in the folder that contains the layer configuration.
Andrea Aime
OpenGeo - http://opengeo.org
Already fixed
WFS-T for udig is only available for WFS 1.0.0, though read-only support exists for 1.1.0. Try setting the VERSION=1.0.0 parameter to the GetCapabilities URL and it _should_ work just as before.
Hope that helps,
Gabriel
Gabriel Roldan
Gabriel Roldan ha scritto:
Already fixed
Gabriel, I was thinking... since udig wfs is fully capable only in v 1.0.0, shouldn't it try to negotiate the usage of 1.0 and fall back
on 1.1 only as a last resort?
Andrea Aime
Already fixed
I guess so, would need to check what's the actual state of it right now on udig... it used to be like that but I'm not completely sure right now.. gonna check
Gabriel Roldan
It negotiates back of the version number is not specified; if the
version number is specified it tries to play along.
Jody
