I updated to latest master, and everything is working fine for me now.
On Wed, Nov 29, 2017 at 9:26 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
I made a tentative fix but there is nobody around herewith a Mac around to verify if it helps.
Let me know
On Tue, Nov 28, 2017 at 7:31 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
I think that happend by accident… the NSG data directory has been copied from the WFS 1.1 one
and then edited via the UI.
My guess is that this editing created the directories with the accents, leaving the ones without there.
I’m at end of day here and still have to write a couple of tests for WFS 2.0 compat fixes, I’ll try to have
a look at it tomorrow
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Tue, Nov 28, 2017 at 7:14 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello All,
In the past week or so, I’ve been running into some issues with some of the new files added under /data, namely the two versions of “data/citensg-1.0/workspaces/sf/sf/EntitéGénérique”
As far as I can determine, there are two folders named the same thing, differing only in the unicode encoding of the “é”.
Some filesystems, including the macOS filesystem, don’t like this (similar to case-sensitive files).
Locally, these two folders are treated as the same folder, which means the files in them are permanently marked as modified and staged, since their contents differ between the two folders.
This makes using the geoserver repo rather difficult.
I have been able to workaround the issue by marking the files as locally ignored, which works fine as long as I stay on master, but means that I can’t switch to older branches that don’t have these files (I get a warning that the changes will get overwritten). This makes backporting commits quite difficult.
So far, I have not been able to find a workaround for changing branches - to do so I have to undo my local ignores, temporarily commit the problematic files, then checkout the old branch and do whatever I need to do there, then later reset the temporary commit when I return to the master branch.
So, I have a couple questions:
Is anyone else having similar issues (I assume it is affecting all macOS developers, I wonder if it also affects Windows developers). If so, have you figured out any alternate workarounds?
Is it absolutely necessary to have two folders with effectively the same name in the same directory? At the very least, is it possible to have them in different directories?
Torben
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
