[Geoserver-devel] Issues with uploading data
I have a problem with uploading my own data to geoserver. Whenever I
load my spatial data to geoserver (using layers function), I can only
do it once before errors in the wicket keep running, even when i try
12 different layers with different attributes and configuration. the
default example layers are ok, but I cannot insert my own layers using
postgis and shapefile method. Already try downloading the software 3
different times, using web-based deployment and window installer.
I am using the latest geoserver safe build, 2.0.2 in window xp sp3.
Would really appreciate any help or clarification on the problem that
I had faced.
I don't understand how inserting data can caused UI problems :frowning:
thanks in advance
On Mon, Jan 3, 2011 at 3:20 AM, Vincent Leong <loldog2000@anonymised.com> wrote:
I had faced.
2.0.2 is too old, try a 2.0.x nightly build here:
http://gridlock.opengeo.org/geoserver/2.0.x/
(those builds are safe, there is basically no development going on
in the 2.0.x series anyways)
If you manage to reproduce the problem there too then open a bug
report on jira.codehaus.org providing detailed steps and eventual
data to reproduce the problem.
And oh, unless you want to discuss your own contributions to the
project (patches, documentation and the like) this is not the right
mailing list. Questions on issues and how to use GeoServer
must be directed to the geoserver-users mailing list.
The devel list is for contributors (and wannabe ones) usage only.
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
