[Geoserver-devel] jaitools dependencies
Hi list,
I had some problems running full build on my machine.
I found out this is because of the jaitools dependencies in wps-core
pom.xml.
After checking the repo, it appears the artifacts have been renamed with jt
prefixes.
I then added the prefixes in front of the artifactIds and it builds
successfully.
The pom.xml needs to be updated like this:
        <dependency>
          <groupId>com.googlecode.jaitools</groupId>
          <artifactId>jt-zonalstats</artifactId>
          <version>${jt.version}</version>
        </dependency>
        <dependency>
          <artifactId>jt-rangelookup</artifactId>
        </dependency>
        <dependency>
          <artifactId>jt-contour</artifactId>
        </dependency>
        <dependency>
          <artifactId>jt-vectorize</artifactId>
        </dependency>
        <dependency>
          <artifactId>jt-utils</artifactId>
        </dependency>
I think it doesn't fail on the buildbot because it only does an update? I
recently reformatted my machine, so it had to download all the artifacts
from scratch.
Rini
View this message in context: http://old.nabble.com/jaitools-dependencies-tp30994104p30994104.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
On Wed, Feb 23, 2011 at 3:26 AM, Rini Angreani Rini.Angreani@anonymised.com wrote:
Hi list,
pom.xml.
prefixes.
successfully.
com.googlecode.jaitools jt-zonalstats ${jt.version} com.googlecode.jaitools jt-rangelookup ${jt.version} com.googlecode.jaitools jt-contour ${jt.version} com.googlecode.jaitools jt-vectorize ${jt.version} com.googlecode.jaitools jt-utils ${jt.version}
I think it doesn’t fail on the buildbot because it only does an update? I
from scratch.
Right, they have been changed recently and the build machine has the old
jars already downloaded. I’m not in a condition to check and commit the
above right now, could you do it directly?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 333 8128928
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Done! Completed: At revision: 15477
<Rini.Angreani@anonymised.com>wrote:
Hi list,
pom.xml.
jt
prefixes.
successfully.
       <dependency>
       </dependency>
       <dependency>
       </dependency>
       <dependency>
       </dependency>
       <dependency>
       </dependency>
       <dependency>
       </dependency>
from scratch.
jars already downloaded. I'm not in a condition to check and commit the
Ing. Andrea Aime
Tech lead
Free Software Download: Index, Search & Analyze Logs and other IT data in
Real-Time with Splunk. Collect, index and harness all the fast moving IT
data
generated by your applications, servers and devices whether physical,
virtual
or in the cloud. Deliver compliance at lower cost and gain new business
insights. http://p.sf.net/sfu/splunk-dev2dev
Geoserver-devel mailing list
View this message in context: http://old.nabble.com/jaitools-dependencies-tp30994104p31000712.html
