[Geoserver-devel] Java 17 compatibility PR ready
I’ve been following up on Bjorn’s work and the Java 17 compatibility PR is ready for review:
https://github.com/geoserver/geoserver/pull/5248
It basically fixes some API incompatibility, upgrades libraries as possible, and adds enough opens in the build to let a full build go. A Java 17 PR check is added in the process, too.
I’ve found that no opens are required to actually run as a webapp, in Tomcat or Jetty, although
the bin package needs a small tweak, the Marlin integration has to be turned off.
I’ve added docs marking Java 17 support as experimental (only did very cursory tests on the default release data directory).
Please check it out!
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
