[Geoserver-devel] Java 21 Github build check active
as discussed in the last PSC meeting, we now have a Java 21 build
in addition to the Java 11 and Java 17 one, checking that the code
builds properly under the new Java LTS.
You’re probably wondering, what does one need to pay attention to?
Mostly likely, nothing, the entire code base was made to build with Java 21
with a handful of changes here:
https://github.com/geoserver/geoserver/pull/7207/files
Long story short, it should be largely transparent, but we want to make sure
the code is working fine on Java 21 as users get that version by default now,
when just going to install “Java”.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
