[Geoserver-devel] Java 8 and test coverage
Hi folks,
not sure if you’re aware, but we are having troubles generating code coverage reports…
Cobertura is unfortunately no longer able to generate reports when using java 8 features in the code,
try it on a module using lambdas and you should stumble into this:
https://github.com/cobertura/cobertura/issues/303
There is a recent fix, but no release:
https://github.com/cobertura/cobertura/pull/299
Plus, one would need a subsequent fix in the cobertura-maven-plugin.
The other option I’ve found is jacoco, but it seems a truly annoying bit of coverage testing
code, as it requires an agent to be run while tests are run, and thus it’s normally setup to always run,
whether you need coverage, or not (if the build gets slower again I’m going to cry murder :wink: )
Wondering if anyone has already some experience and maybe has and already tested way
to make it only run on demand?
It’s not like we need code coverage tools right now, we can wait the first module in need of graduation
will have to demonstrate the code coverage level… but imho one should just have to concentrate
on getting the module good :wink:
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hey,
FWIW we’re using jacoco for geogig, and moved it to a profile due to the reasons you mentioned.
https://github.com/locationtech/geogig/blob/dev/src/parent/pom.xml#L588
On Mon, Jun 20, 2016 at 11:22 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi folks,
Ing. Andrea Aime
@geowolf
Technical Lead
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports. http://sdm.link/zohomanageengine
Geoserver-devel mailing list
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com
@boundlessgeo
Ah ha, thanks Gabriel, that’s interesting.
Wondering, is the tools also able to report cross-module coverage in a multi-module setup?
And how do you run it, is that a “mvn -Pjacoco site” ?
On Thu, Jun 23, 2016 at 1:34 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hey,
Hi folks,
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@boundlessgeo
Ing. Andrea Aime
@geowolf
Technical Lead
I run mvn clean install -Pjacoco whenever I want to generate the reports.
In terms of aggregating multi project reports, I’m just looking into that, seems it doesn’t come out of the box.
On the other hand, I’d be interested in installing the following Jenkins plugin in ares: https://wiki.jenkins-ci.org/display/JENKINS/JaCoCo+Plugin
If that also seems of interest for GeoServer that’d be a more compelling reason to push it forward
On Thu, Jun 23, 2016 at 8:37 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hey,
Ing. Andrea Aime
@geowolf
Technical Lead
Hi folks,
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@boundlessgeo
Gabriel Roldán
groldan@anonymised.com39…
@boundlessgeo
On Thu, Jun 23, 2016 at 1:53 PM, Gabriel Roldan <groldan@anonymised.com>
In terms of aggregating multi project reports, I'm just looking into that,
seems it doesn't come out of the box.
On the other hand, I'd be interested in installing the following Jenkins
If that also seems of interest for GeoServer that'd be a more compelling
I cannot say I'm dying to have it, but having a period report of code
coverage sure does not hurt :slight_smile:
+1 on installing it
Ing. Andrea Aime
@geowolf
Technical Lead
ok, talking to Chris Del Pino to get it installed.
Gabriel
On Thu, Jun 23, 2016 at 9:07 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Jun 23, 2016 at 1:53 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
I cannot say I’m dying to have it, but having a period report of code coverage sure does not hurt :slight_smile:
+1 on installing it
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@boundlessgeo
+1 too
Ian
On 23 June 2016 at 13:07, Andrea Aime <andrea.aime@anonymised.com> wrote:
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
+1 on installing it
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
okay so the plugin is installed and it does the multi module aggregation for you, which is good.
As mentioned before, we’ve moved the jacoco maven plugin configuration to a profile, and running the dev branch build with mvn clean install -Pjacoco …
Once you enable Jacoco reporting on the build config, you’ll get a summary chart for each build, on the “Coverage Trend” side bar entry.
When clicking on the chart takes you to the full report, like this one <http://ares.opengeo.org/jenkins/view/geogig/job/geogig-dev/84/jacoco/>
One slightly odd thing I found it may report missing coverage for modules that no longer exist. That’s because the .exec files jacoco generates contains the coverage data, and it also uses all .class files to generate the report. So, if a module no longer exists or is not part of the build, but old .class files are lying around in the workspace, it’ll take it as a miss. Which would easily be worked around by using a clean workspace on each build.
On Thu, Jun 23, 2016 at 10:09 AM, Ian Turton <ijturton@anonymised.com> wrote:
+1 too
Ian
Ian Turton
+1 on installing it
Ing. Andrea Aime
@geowolf
Technical Lead
Gabriel Roldán
@boundlessgeo
