[Geoserver-devel] java 8, spring asm compatibility troubles...
Kevin has been bashing his head against a very complicated failure today …
Spring asm is repackaging of asm (bytecode manipulation and analysis framework). It is tripping over itself as Kevin gleefully tries out Java 8 features like streams.
GWC uses spring 3.1.1, the nearest release compatible with Java 8 seems to be:
TLDR: Not sure we are Java 8 ready yet
Jody Garnett
From what I can see, simply having Java 8 bytecode as a target opens up this problem. Using Java 8 specific language constructs (Lambdas, etc) merely makes problems more likely to manifest, as I found while doing some work on GeoWebCache. This is an assortment of horrifically obtuse looking bugs waiting to happen.
spring-asm is a dependency of spring-core so it could be potentially being used anywhere spring is.
Kevin Michael Smith
smithkm@anonymised.com
Spring 4.0.3
It’s my pleasure to announce that Spring Framework 4.0.3 is available. This is the first release of the framework after Java 8’s launch last week; it is built with OpenJDK 8 GA now and includes the latest ASM 5.0.1 (with bytecode support at the JDK 8 GA level as well, superseding the custom ASM 4.2 fork that we were previously using).
Jody Garnett
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-devel mailing list
So if upgrading to spring 4.0.3 is the earliest feasible version, what else is around … spring 4.2.4 is current.
Justin had some notes on Oct 23rd on upgrading spring:
Kevin Michael Smith
Spring 4.0.3
Jody Garnett
Jody Garnett
If I recall correctly upgrading to any 4.x version will be an issue because of spring security. See past email for the details. If my poor memory serves me right I tried upgrading to 4.0.x or 4.2.x and ran into an issue with security. Upgrading that to even 3.2.x led to issues previously discussed.
Jody Garnett
Kevin Michael Smith
Spring 4.0.3
Jody Garnett
From a quick look at the Spring migration guide. It sounds like the core of spring has been fairly stable, but the peripheral libraries may be more of a problem.
I tried updating GWC to Spring 4.2.4 and the Spring JDBC API seems to have changed quite significantly. After making a quick effort squash compiler errors It builds, but has quite a few unit test failures in the JDBC Diskquota module.
Otherwise it seems to work, although GWC’s unit test coverage is less than stellar.
Kevin Michael Smith
Hey folks,
I am working on a project where I need to integrate some custom code into GeoServer that requires a newer version of spring than is currently used. I was wondering if anyone would be opposed to a spring upgrade on master?
If not, then the question becomes what to upgrade to? Currently the code base depends on spring 3.1.x. The current release of spring is 4.2.x. I haven’t explored how much work upgrading to 4.2.x will be but a while back I did look at upgrading to 3.2.x and the changes were pretty simple.
My vote (fwiw) would be to explore the upgrade to 4.2.x and if we encounter any blockers potentially upgrade to 3.2.x for the time being.
Let me know what y’all think.
Thanks!
-Justin
Jody Garnett
Kevin Michael Smith
Spring 4.0.3
Jody Garnett
On Thu, Feb 25, 2016 at 12:50 AM, Jody Garnett <jody.garnett@anonymised.com>
Spring asm is repackaging of asm <http://asm.ow2.org> (bytecode
Can we get some more specifics on this issue?
As far as I know spring-asm is used mostly to decorate spring beans, I'm
wondering what the specific issue is.
In GeoServer we already have code using lambdas and it does not seem to be
affected, but it's mostly present in the
UI layer that is not instantiated by Spring.
In particular, I'm wondering if this might be affecting the release...
don't think so, since everything seems to be working
fine, but at the very least we should be able to document/warn people
writing extensions about known failure
cases
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hum… between Justin’s report back then, and what Kevin said, it seems we’re
getting on our hand into anther “wicket upgrade” case, hopefully not as big.
I don’t see suitable code sprints for this upgrade in the incoming year though… (Bonn has two days,
but in all honesty, who’s going to participate to the sprint day before the conference? Most
of the people I know would use it to complete the presentation slides :wink: )
On Thu, Feb 25, 2016 at 2:59 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
On Wed, Feb 24, 2016 at 5:30 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Hey folks,
Thanks!
-Justin
Jody Garnett
Kevin Michael Smith
Spring 4.0.3
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Kevin was using streams in some GWC code, the resulting failure (an array out of bounds failure) was a bit random. Putting break points in eclipse did not work, the asm modified bean had tripped up over the Java 8 byte codes and had lost the association between byte code and line numbers.
Kevin has more details, and a wider range of problems, it did not so far seem very deterministic.
On 24 February 2016 at 23:23, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Thu, Feb 25, 2016 at 12:50 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
As far as I know spring-asm is used mostly to decorate spring beans, I’m wondering what the specific issue is.
In GeoServer we already have code using lambdas and it does not seem to be affected, but it’s mostly present in the
In particular, I’m wondering if this might be affecting the release… don’t think so, since everything seems to be working
fine, but at the very least we should be able to document/warn people writing extensions about known failure
cases
Ing. Andrea Aime
@geowolf
Technical Lead
found this one on the net:
http://stackoverflow.com/questions/24657418/spring-core-3-2-9-java-8
The issue in particular is talking about static interfaces, Kevin, does that match your case… it makes
a lot more sense than streams per se, in that asm is not designed to implement proxies
for interfaces with default methods.
This other topic is also of interest:
http://stackoverflow.com/questions/30072135/spring-3-2-x-with-java-8/33936697#33936697
So… from what I gather, we should be good unless we are using Spring annotations causing
classpath scan (which afaik we do not, except in the rest services that Niels implemented for
the internal GeoFence API, e.g. https://github.com/geoserver/geoserver/blob/master/src/community/geofence-server/src/main/java/org/geoserver/geofence/rest/RolesRestController.java)
and as long as the interfaces of the beans that need to be proxies are using Java 7 rules.
I haven’t heard of issues with the GeoFence module yet… maybe because the beans are
also manually declared in the spring context, and we are not actually enabling Spring
classpath scanning?
On Thu, Feb 25, 2016 at 8:23 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
cases
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Yeah geofence-server is not using context:component-scan.
Beans are still declared manually.
It is only using <mvc:annotation-driven /> for the MVC annotations inside the controllers.
Regards
Niels
On 02/25/2016 10:11 AM, Andrea Aime wrote:
classpath scanning?
cases
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
[http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140](http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
It might be the Spring Annotations. I think I remember using that somewhere in GWC.
Kevin Michael Smith
Regards
Niels
classpath scanning?
cases
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net) [https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
No, that was XStream annotations I was thinking of.
Kevin Michael Smith
Kevin Michael Smith
Regards
Niels
classpath scanning?
cases
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
