Hi guys,
I'm writing this in english since I guess It may be of interest for other
projects, so I'm cc'ing this message to the appropriate lists.
First, I want to adhere to Alvaro's congratulations for the great job you're
doing with gvSig, and raise up some questions.
FYI: the gvSig team has managed to include Java bindings for GDAL inside its
product.
As it become obvious, java access to gdal may be of great interest for the
GeoServer WMS/WCS implementations. My questions are:
- do you know if access to gdal is thread safe? I guess I have read from the
gdal creator that it is not still thread safe. Do you know if it would be
suitable for a server usage?
- do you have plans (if not already done) to commit and maintain the Java
bindings for GDAL at the GDAL source tree? I ask because it seems like a long
waited contribution on the GDAL site and forums.
Geoserver WCS guys: are you interested in accessing rasters through GDAL? if
so, are you interested in coordinating with gvSig team to inspect the
possibilities in the short term? or may be you are focused on higher level
stuff right now?
I guess it could be a huge capability for geoserver. If you're not interested
may be I could arrange some 'spare' time to dedicate, but it would be really
fantastic if you're interesting at least in investigating the possibilities
of integration.
Alvaro: are you working on an OGC map server or a custom one? if the former,
would you be interested in adding gdal support to GeoServer WMS?
Best regards and thanks to all of you for the great stuff you're working on.
Gabriel.
On Tuesday 27 September 2005 09:15, Alvaro Zabala wrote:
Hola a todos,
En primer lugar quería felicitar al equipo de gvSIG por su gran labor.
En mi opinión, gvSIG es mucho más que un herramienta final de usuario,
y gracias a su diseño modular ha puesto a disposición del resto de la
comunidad GIS muchas funcionalidades hasta ahora no cubiertas, y
perfectamente reutilizables con relativo poco esfuerzo.En el caso que nos ocupa, en mi organización estamos implantando un
servidor de mapas basado en sw libre, y para no tener que convertir
toda la imaginería raster (en formato Mr.SID, unos 12 DVDs de doble
cara y capa) a ECW hemos incluido soporte para Mr.SID gracias a la
librería de gvSIG jmrsid.Ahora vienen mis dudas. Las primeras pruebas funcionales las pasa sin
problemas, pero al estar basado en una DLL-gdal-, querría saber si se
han detectado problemas en el manejo de la librería. Por poner un
ejemplo, la librería ECW de ER-Mapper en este sentido es una
calamidad. La DLL debe mantener una caché de tiles, y desde el API
Java no hay manera de liberarla. Esto obliga a tener que implementar
truquitos, como cerrar el fichero cada X imágenes procesadas, o
controlar externamente la resolución de las imágenes que se quieren
obtener de la librería, pues esta no permite remuestrear.¿Es jmrsid-gdal- estable en este sentido? ¿Se arreglaron los problemas
que daba gdal en el manejo de MrSID a principios del 2005?Un saludo a todos, y gracias de antemano.
Alvaro Zabala Ordóñez
Miembro fundador de AGIL
Asociación para la promoción del GIS Libre
www.agiles.orgFuncionario del Cuerpo de Gestión de Sistemas e Informática de la
Administración General del Estado.
Confederación Hidrográfica del Guadalquivir.
Teléfono: 954939523
Plaza de España, sector II.
SEVILLA_______________________________________________
gvSIG_desarrolladores mailing list
gvSIG_desarrolladores@anonymised.com
http://runas.cap.gva.es/mailman/listinfo/gvsig_desarrolladores
