Hi developers,
I see following Javascript error in Geoserver admin gui, when resizing the window.
Uncaught TypeError: Cannot set property ‘disabled’ of null
at resizeStylePage (VM840 jquery.fullscreen-ver-D69DCBA0FF6B036BBEEE78538C81855F.js:22)
geoserver-2.17.0\src\web\core\src\main\java\org\geoserver\web\js\jquery.fullscreen.js:22 is
document.getElementById(‘cm_editor_heigth’).disabled=false;
cm_editor_heigth is (only) available in StyleEditorPage. So on other pages getElementById(‘cm_editor_heigth’) is null !
Maybe it would be better to change jquery.fullscreen.js on line 17 to
if (document.getElementById(‘cm_editor_heigth’)) {
document.getElementById(‘cm_editor_heigth’).disabled=true;
and on line 28 to
Existing code:
if (isFullscreen) {
if (document.gsEditors) {
//update the default to the old value
editorDefault = document.gsEditors[“editor”].getWrapperElement().offsetHeight;
editorHeight = Math.max(300, windowHeight - editorMargin);
previewHeight = Math.max(300, windowHeight - previewMargin);
} else {
var editor = document.gsEditors[“editor”];
editor.setSize(“100%”, editorHeight);
editor.refresh();
Stefan
Dipl. Ing. Stefan Overkamp
Laakmannsbusch 44, 42555 Velbert
tel.: 0177 / 79 76 159
[overkamp@...6003...](mailto:overkamp@...6003...)
This is great information - can you open an issue at https://osgeo-org.atlassian.net/projects/GEOS/issues and ideally submit a PR with the change in it at https://github.com/geoserver/geoserver
Thanks again for your help
Ian
Ian Turton
I will try. Have never done a pull request.
Stefan
Am 14.05.2020 um 10:09 schrieb Ian Turton:
Ian
On Thu, 14 May 2020 at 08:45, Stefan Overkamp <overkamp@anonymised.com
<mailto:overkamp@anonymised.com>> wrote:
Hi developers,
Uncaught TypeError: Cannot set property 'disabled' of null
is
document.getElementById('cm_editor_heigth').disabled=false;
other pages getElementById('cm_editor_heigth') is null !
if (document.getElementById('cm_editor_heigth')) {
document.getElementById('cm_editor_heigth').disabled=true;
andon line 28 to
Existing code:
if (isFullscreen) {
editorDefault = document.gsEditors["editor"].getWrapperElement().offsetHeight;
} else {
var editor = document.gsEditors["editor"];
editor.setSize("100%", editorHeight);
editor.refresh();
Stefan
overkamp@anonymised.com <mailto:overkamp@anonymised.com>
Geoserver-devel mailing list
<mailto:Geoserver-devel@lists.sourceforge.net>
Ian Turton
I've submitted a pull request:
https://github.com/geoserver/geoserver/pull/4245
But I have not referenced the number of the JIRA ticket in the commit.
Sorry.
Stefan
P.S. I think I need some advice from developers to do everything correct.
Ian
Hi developers,
is
andon line 28 to
Existing code:
if (isFullscreen) {
} else {
editor.refresh();
Stefan
Ian Turton
