[Geoserver-devel] Jboss and Geoserver
The FAQ entires for Jboss seem to be a little out of date.
This is how to get it to work under linux
copy geoserver.war to the deploy directory eg server/default/deploy
Define the envronmental varible JAVA_OPTS to be
JAVA_OPTS="-DGEOSERVER_DATA_DIR=path/name"
export JAVA_OPTS
then use run.sh to start up geoserver
If you do not define JAVA_OPTS any config changes will be deleted the next time you restart jboss or redploy geoserver.
Dave.
Hi Dave,
Which FAQ entry are you referring to? I only see one about Logging in Jboss...
Aside, would you perhaps be interested in updating the FAQ directly on the wiki?
export JAVA_OPTS
Dave.
!DSPAM:4007,4862c4a371761030819293!
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
