Hi Everyone,
We have a pull request for the jdbc resource store (as well as some additional resources port commits )
See https://github.com/geoserver/geoserver/pull/1361
It has been fully reviewed by Ben, but there is some new resources related stuff added to the platform module that I wanted to check with the community as well.
1) There is kind of some new API, but it is completely separate from the existing API (and does not alter any existing API in any way): the ResourceWatcher interface with SimpleResourceWatcher implementation.
See this commit: https://github.com/NielsCharlier/geoserver/commit/3d36223546bea462d972e931152dc07a2b5039e7
This is an interface/class that, completely separately from the file system (hence it is not used by the default resource store implementations) store resource listeners, receives resource notifications and sends these to the listeners. The interface allows us to implement a clustered version in the hzcluster module that works perfectly together with the jdbcresourcestore without either of those two modules depending on each other.
It is not being used for anything else as of yet but it can be used by other resource implementations and other cluster implementations as well.
2) Following up on the resources port, I have also added some new utility methods to the Resources class.
https://github.com/NielsCharlier/geoserver/commit/daa934dcacf3064cf14ff5d32f0d16537e7f3598
Previously, we had Files.url(String)->File, taking a url as a String and returning a File. And we had GeoServerDataDirectory.urlToResource(URL)->Resource which supports a custom "resource:" scheme (which was unsupported by the url(String) method).
Instead, I have created instead Resources.fromURL(URL)->Resource and Resources.fromURL(String)->Resource which both support the "resource:" scheme (in analogy with the already earlier added fromPath(String)).
The Files.url(String)->File is now calling Resources.fromURL() and has been deprecated.
Kind Regards
Niels
