[Geoserver-devel] JDBC Store implementation guidelines
Hello,
Is there any guideline on how to evolve an existing module to make it compatible with the jdbcstore community extension?
I need to use the feature-pregeneralized extension with this store and for the moment it does not work.
The extension currently uses the Resources.find method to find a reference to the configuration file: I assume I shall change the code to use a class derived from
org.geoserver.platform.resource.ResourceStore
instead
Alexandre Gacon
Alexandre:
The original proposal had example code snippets; and I did my best to add very good javadocs for using ResourceStore.
Jody Garnett
Thanks Jody for the input. I have already implemented a first version (which of course does not work) and I will have a look at the examples to see what I did wrong.
Alexandre
Alexandre Gacon
If you make a draft PR I am happy to provide input. I presently do not have any customers using JDBCStore but I am happy to support your troubleshooting.
If I remember it really just wants a data structure for configuration; and it needs to callback to the geoserver catalogue to look up data stores being referenced.
Good fun.
Jody Garnett
I will do that after doing some additional investigation on my side.
Alexandre
Alexandre Gacon
Jody, a draft PR is available here : https://github.com/geoserver/geoserver/pull/6121.
Alexandre Gacon
