I believe you did the 1.7.3 release? The GT 2.5.4 jars are not deployed and I can't build this stable release. Are you able to deploy them?
Graham Davis
Refractions Research Inc.
gdavis@anonymised.com
Graham Davis
I have not uploaded them yet, i have not been over a good enough connection to do the release. I am not though so i can fire off the deployment. Will let you know when its done.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
2.5.4 should be uploaded no on both the osgeo and opengeo maven repositories.
Justin Deoliveira
Thanks Justin, I'll give it a go now!
Graham.
Graham Davis
Justin, seems like 1.7.3 stable has test failures in the build:
T E S T S
Running org.geoserver.wcs.DescribeCoverageTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 2.891 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.046 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.157 sec
Running org.geoserver.wcs.GetCoverageTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.172 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.687 sec
Running org.geoserver.wcs.GetCoverageMultipartEncodingTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.047 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@14f5a31
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.421 sec
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.234 sec
Running org.geoserver.wcs.GetCapabilitiesTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.032 sec <<< FAILURE!
Results :
Tests in error:
Tests run: 25, Failures: 0, Errors: 5, Skipped: 0
Graham.
Graham.
Graham Davis
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.032 sec <<< FAILURE!Results :
Tests in error:
org.geoserver.wcs.GetCapabilitiesTestTests run: 25, Failures: 0, Errors: 5, Skipped: 0
Hum, I just checked out 1.7.3 and built it. It downloaded the 2.5.4
jars from the repo, as I haven't ever built them, so we should
be in the same conditions, but my build was completely successfull.
May it be that you're building with JDK 1.6? GeoServer and GeoTools
are built with Sun JDK 5 only, due to minor differences in the behaviour
of the two JDK none of the actually builds with JDK 6.
Andrea Aime
Ah yes, looks like my JAVA environment variables have been changed since I last built GS. Thanks Andrea!
Graham.
T E S T S
Tests in error:
of the two JDK none of the actually builds with JDK 6.Cheers
Graham Davis
