Everyone is posting individual updates this time around; here’s mine:
XML Schema test failures are now fixed on Jenkins and geoserver-java11 now passes all tests. See the preexisting email thread for more details; ultimately it wasn’t actually a Java 11 issue.
Sometime today, I ran into some test failures in GeoServer; if you encounter failures along the line of java.lang.ClassNotFoundException: javax.xml.bind.JAXBException, try updating and rebuilding GeoTools a couple times.
All GeoServer core/extension tests should be passing on all platforms now.
Torben
