The Spring 5.1 branch was tested on a bunch of different machines and configurations.
I’ve also built a system independant binary off that branch, and tested it against a 2.14 data dir with some encrypted postgis credentials, and all the passwords seemed to work fine.
Monitor hibernate was failing tests after the Spring 5.1 update. Since it was a community module, it has been removed from the communityRelease profile until a maintainer can fix it.
The Spring 5 branch has been merged into jdk11 and should be stable.
Kevin has been looking into split packages for GWC, still in progress here: GitHub - smithkm/geowebcache at jdk11-split
Next steps:
The bulk of what is left is moving split packages around; see Jody’s update for more details about the GeoTools split packages.
Jim and Jody believe that none of the EMF modules have split packages, so if Ian’s work becomes ready to merge it won’t conflict wth the repackage.
GeoServer split packages still need resolving
Apart from that, more testing is always good. If anyone could make a table of what testing has been done, that would be appreciated.
We should also start putting together a blog post describing the sprint and thanking sponsors, etc.
Torben
Hi Torben,
should we merge the gwc and gs jdk11 branches to master then, and kick the CITE tests, so that we
can see where we stand?
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
