Complete:
- GeoTools now passes tests everywhere
- Various misc updates, see spreadsheet
- Found more GWC and GeoServer test failures, see spreadsheet
Awaiting review:
- [tbarsballe] GWC - Remove ImageIO API: https://github.com/GeoWebCache/geowebcache/pull/699
Separate from but related to this change, GeoWebCache also references several ImageIO classes when configuring ImageEncoderImpl and ImageDecoderImpl in geowebcache-wmsservice-context.xml - Given that these are string arguments, we don’t have to change them, but I wonder if switching to some solution utilizing
ImageIO.getImageReadersByMIMEType
instead of a direct class lookup might be better?
- [jgarnett] JAITools jdk11 javadocs: https://github.com/mbedward/jaitools/pull/235
- [smithkm] Log4J update: https://github.com/GeoWebCache/geowebcache/pull/700
In Progress:
- [smithkm] GeoWebCache: Spring 5 update, was blocked by Log4J issues (see above).
- [vickdw] GeoServer: Spring 5 update - Spring Security updates currently in progress, API has changes rather substantially since 4.x.
Help would be appreciated. Current status is here, if anyone is able to take a look, and perhaps suggest improvements: https://github.com/vickdw/geoserver/tree/spring-5.1
There is also some useful background information about the spring security changes:
https://docs.spring.io/spring-security/site/docs/current/reference/htmlsingle/#core-services-password-encoding
https://github.com/spring-projects/spring-framework/wiki/Upgrading-to-Spring-Framework-5.x
https://github.com/spring-projects/spring-security/issues/4874
- [dtucker] GeoServer: gs-platform/gs-web-core usage of RenderingEngine in progress.
- [jnh5y] Currently populating Stage 3 of the spreadsheets with package splits.
