[Geoserver-devel] JDK11 sprint: should we color code the task lines?
quick proposal, should we color code the task lines in order to see their resolution at a glance?
Proposal:
  • Leave white for tasks not tackled or in progress
  • Green: issue solved
  • Yellow: nothing we can do now (e.g., we’re waiting for an upstream library) or we just decided it was not important
  • Red: at a loss, need someone else to look into it
    Or instead of color coding, we could have a “state” column with the various states (and we give a color to the options)
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
That sounds useful, although it might be worthwhile to mention this on Gitter too, as I am not certain everyone involved is paying attention to the geoserver devel list. I’ll mention it to the North America participants.
Torben
On Sun, Oct 21, 2018 at 12:44 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Proposal:
Geoserver-devel mailing list
