[Geoserver-devel] Jenkins 2.4-cite-wfs-1.1 hangs infinitely
Justin,
Jenkins 2.4-cite-wfs-1.1 hangs infinitely so I had to kill it as it was blocking the queue:
http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/4/
Any ideas what could be causing this? I picked through the Jenkins setting but could not think of anything.
Once we have got this to pass (at least one, it has never passed on ares!), I can start the release train.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Hey Ben,
No I don’t. I suggest you don’t wait on the build server since I don’t know when I will be able to solve the problem. Instead I would run the cite tests locally.
-Justin
On Tue, Oct 15, 2013 at 3:36 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Justin,
Kind regards,
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Fwiw I just ran the wfs 1.1 tests locally and they passed, although they hang for me locally as well. I am continuing to investigate.
On Tue, Oct 15, 2013 at 8:14 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hey Ben,
-Justin
Justin Deoliveira
@j_deolive
Justin,
Kind regards,
Software Engineer
Justin Deoliveira
@j_deolive
Ok, I think i have this all sorted out now. Well sort of. The wfs job hangs because teamengine is keeping some lingering threads around. Why i can’t figure out. I can reproduce it both locally and on ares but not on the old gridlock. As to why, beats me. For now i have just updated the scripts to kill the teamengine instance after a certain period of time and that seems to work, be it a nasty hack.
Other failures were due to locale issues and the EntiteGenerique layer. Fixed now.
So Ben looks like cite is happy so you are good to go :slight_smile:
On Tue, Oct 15, 2013 at 9:13 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Justin Deoliveira
@j_deolive
Hey Ben,
-Justin
Justin Deoliveira
@j_deolive
Justin,
Kind regards,
Software Engineer
Justin Deoliveira
@j_deolive
Thanks heaps, Justin. It looks like your fix worked. I will light the blue touch paper.
Kind regards,
Ben.
can't figure out. I can reproduce it both locally and on ares but not on
Fixed now.
        Hey Ben,
        No I don't. I suggest you don't wait on the build server since I
        don't know when I will be able to solve the problem. Instead I
        -Justin
        <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
            Justin,
            http://ares.opengeo.org/__jenkins/job/2.4-cite-wfs-1.1/__4/
            <http://ares.opengeo.org/jenkins/job/2.4-cite-wfs-1.1/4/&gt;
            Kind regards,
            Software Engineer
        *Justin Deoliveira*
        @j_deolive <https://twitter.com/j_deolive&gt;
    *Justin Deoliveira*
*Justin Deoliveira*
Software Engineer
