[Geoserver-devel] Jenkins build job to publish GeoServer ACL maven artifacts
Hey Jody,
For the GeoServer ACL we have github CI build jobs [1], but IIRC you mentioned you didn’t want maven repo credentials spread over anything but build.geoserver.org.
It looks like I do have permissions to create new build jobs, but I’d need some assistance in setting up the credentials to publish the maven artifacts.
How do you think we should proceed?
TIA,
Gabe
[1] https://github.com/geoserver/geoserver-acl/actions
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Gabriel Roldán
Geospatial Developer
Gabe:
Please give it a go setting up jobs on build.geoserver.org - you can use the existing jobs as an example of how to work with the credentials?
If you look at the existing jobs that deploy they are configured with a maven settings.xml file.
Jody Garnett
Got it. After a couple failed attempts got it working. Thanks a lot.
El El vie, 21 de abr. de 2023 a la(s) 14:49, Jody Garnett <jody.garnett@anonymised.com> escribió:
camptocamp
Gabriel Roldán
