Hello All,
I will be enabling notifications for all builds on build.geoserver.org, and disabling the corresponding jobs on ares.boundlessgeo.com.
If you are seeing excess notifications, this is probably why.
Torben
Hello All,
Torben
All notifications have now been turned on for build.geoserver.org, and the corresponding jobs on ares.boundlessgeo.com have been disabled, with the following exceptions:
geofence: All the geofence-*-nightly jobs are currently failing on build.geoserver.org. The issue seems to be in maven; from what I can determine some of the declared dependancies do not have valid artifacts available. This likely required a change in the pom (I expect ares may have has some jars manually installed in order for the build to work, although I have not been able to replicate this successful configuration).
geoscript: The geoscript.org build fails; it appears to depend on an old version of ant and maven, which are not available on build.geoserver.org. Either the build needs to be updated, or these should be installed on build.geoserver.org.
These to jobs are currently still enabled on both ares and build.geoserver.org.
Torben
On Fri, Nov 24, 2017 at 9:23 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello All,
If you are seeing excess notifications, this is probably why.Torben
probably the valid artifacts were downloaded when they were available, and
then they remained available locally.
Looking into this.
Emanuele
following exceptions:geofence: All the geofence-*-nightly jobs are currently failing on
have not been able to replicate this successful configuration).geoscript: The geoscript.org build fails; it appears to depend on an old
build.geoserver.org.These to jobs are currently still enabled on both ares and
build.geoserver.org.Torben
> Hello All,
> Torben
Hi Torben,
(a previous reply of mine got lost somehow :|)
There are some problems in the local maven repo in jenkins, since the error is
about reading some local files (opening the zip/jar file and reading a pom file).
I modified the build configuration for geofence-master-nightly, setting the
"use private maven repository" option.
Once done that, maven did download again all the required dependencies, and
the build succedeed.
I could repeat this workaround for all the other failing jobs, but this would
not be optimal. I guess that getting into the system and deleting the bad files
would be the Good Thing to do.
Emanuele
> Hello All,
> Torben
Ing. Emanuele Tajariol
Technical Lead
Via di Montramito 3/A
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo
è consentito esclusivamente al destinatario del messaggio, per le finalità
indicate nel messaggio stesso. Qualora riceviate questo messaggio senza
esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-
mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal
Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely for the
attention and use of the named addressee(s) and may be confidential or
proprietary in nature or covered by the provisions of privacy act (Legislative
Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not
in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly
forbidden except previous formal approval of the named addressee(s). If you
are not the intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message that has
been received in error. The sender does not give any warranty or accept
liability as the content, accuracy or completeness of sent messages and
accepts no responsibility for changes made after they were sent or for other
risks which arise as a result of e-mail transmission, viruses, etc.
Fixing that maven problem, another interesting issue arose while building
GeoFence, concerning hibernate-spatial dependencies.
Since I guess it can be of general interest I'm linking it here:
https://github.com/geoserver/geofence/issues/97
Emanuele
Alle 11:09:42 di Wednesday 6 December 2017, Emanuele Tajariol ha scritto:
Hi Torben,
> build.geoserver.org. The issue seems to be in maven; from what I canThere are some problems in the local maven repo in jenkins, since the error
is about reading some local files (opening the zip/jar file and reading a
pom file).I modified the build configuration for geofence-master-nightly, setting the
would not be optimal. I guess that getting into the system and deleting
the bad files would be the Good Thing to do.Cheers,
> configuration).
> Torben
> > Hello All,
> > Torben
Technical Lead
On Wed, Dec 6, 2017 at 2:09 AM, Emanuele Tajariol <etj@anonymised.com>
wrote:
Hi Torben,
error is
would
files
I actually tried that when debugging the issue initially - when I deleted
the problematic jars from the maven repo, new jars with the same problem
just got downloaded (hence why I though it was an issue with the artifacts
themselves).
Perhaps one of the repos that the geofence build is pulling from has
corrupt artifacts?
Good to know that there is a workaround to get master building for now at
least.
Torben
the
have
although I
> Torben
> > Hello All,
> > Torben--
Emanuele TajariolGeoServer Professional Services from the experts! Visit
GeoSolutions Enterprise Support Services
for more information.Ing. Emanuele Tajariol
Technical LeadGeoSolutions S.A.S.
fax: +39 0584 1660272http://www.geo-solutions.it
x.com-------------------------------------------------------
nel/i
utilizzo
e-
dal
diverse,
196/2003.The information in this message and/or attachments, is intended solely for
the
(Legislative
not
has
other
