On Fri, Feb 3, 2017 at 10:43 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I will add it to the wiki page, trodden has a bug reports already in play GEOS-7873 / GEOS-7771.
Jody Garnett
On 3 February 2017 at 10:05, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
I like your proposal
On Fri, Feb 3, 2017 at 4:40 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Okay idea:
a) Can you apply your evil reflection hack so we get valid JSON output in the short term - maintaining REST API 1.0 JSON Output
b) Can we upgrade Jackson as part of the code-sprint - producing a REST API 1.0.1 JSON Output
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Jody Garnett
On 2 February 2017 at 23:39, Torben Barsballe <tbarsballe@anonymised.com> wrote:
The main reason we appear to be using Jettison is that it directly integrates with XStream, which means we have very little custom code for JSON, and just use the XML-based code, relying on XStream/Jettison for the conversion.
Ultimately, changing to a different JSON library while maintaining current functionality would either involve forking Jettison, or tying in a new library with the existing REST API, which would likely be an immense amount of work.
There is an alternate Jettison library that is supported by XStream, but it does not support deserialization, which is required for the REST api, and I don’t think it is any better supported than the current one.
Torben
On Thu, Feb 2, 2017 at 9:36 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Torben,
you mentioned in the pull request that the jettison project appears to be poorly documented, poorly supported, and has not had many recent commits. This suggests that, even if we upgrade to a later version of jettison, we will be left a dependency that might cause further problems in the future. Are there any comparable libraries with better support? If so, how hard would it be to migrate? If we are going to break the API anyway, this would be an ideal time to switch implementation.
Kind regards,
Ben.
On 01/02/17 07:18, Torben Barsballe wrote:
Proposal created here: https://github.com/geoserver/geoserver/wiki/GSIP-156
Torben
On Tue, Jan 31, 2017 at 10:49 AM, Torben Barsballe <
tbarsballe@anonymised.com39…> wrote:
Slight point of clarification - currently lists containing a mix of nulls
and objects are coming out as invalid JSON. The only observed place where
this happens is with LayerGroups (specifically the style list, where null
represents “use the default style”).
Since the API-breaking fix is definitely not backportable, it might make
sense to apply the alternative fix to the current stable branch (although I
am not especially happy having that level of reflection anywhere in the
codebase)
I am happy to make a proposal for the “proper”, API-breaking fix.
Torben
On Tue, Jan 31, 2017 at 10:38 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Taking this pull request discussion to the email list as it has some
strategic consequences - so we probably need a proposal.
Torben has two “fixes”:
- a good fix, updating the version of jettison - that breaks REST API
compatibility (sigh)
- a bad fix, using reflection to hack - produces valid JSON code but a
brittle fix
What would we like to do? Currently empty lists are coming out as invalid
JSON.
Jody Garnett
Director
Transient Software Limited <http://transient.nz/>
New Zealand
