Andrea,
here is the full console output when trying the start GeoServer from geoserver-2.8-SNAPSHOT-bin.zip. This causes the CITE failures on Jenkins and is blocking the 2.8.1 release.
Is it as simple as a missing log4j dependency?
Kind regards,
Ben.
ben@anonymised.com:~/tmp/geoserver/geoserver-2.8-SNAPSHOT$ bin/startup.sh
GEOSERVER_HOME environment variable not found, using current
directory. If not set then running this script from other
directories will not work in the future.
GEOSERVER DATA DIR is /home/ben/tmp/geoserver/geoserver-2.8-SNAPSHOT/data_dir
2015-11-18 08:52:36.453::INFO: Logging to STDERR via org.mortbay.log.StdErrLog
2015-11-18 08:52:36.556::WARN: Deprecated configuration used for /home/ben/tmp/geoserver/geoserver-2.8-SNAPSHOT/webapps
2015-11-18 08:52:36.576::INFO: jetty-6.1.8
2015-11-18 08:52:37.490::WARN: failed org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,file:/home/ben/tmp/geoserver/geoserver-2.8-SNAPSHOT/webapps/geoserver/}
java.lang.NoClassDefFoundError: Could not initialize class org.apache.log4j.Logger
at org.geotools.util.logging.Log4JLoggerFactory.getImplementation(Log4JLoggerFactory.java:65)
at org.geotools.util.logging.Log4JLoggerFactory.getImplementation(Log4JLoggerFactory.java:33)
at org.geotools.util.logging.LoggerFactory.getLogger(LoggerFactory.java:79)
at org.geotools.util.logging.Logging.getLogger(Logging.java:200)
at org.geoserver.platform.GeoServerResourceLoader.<clinit>(GeoServerResourceLoader.java:62)
at org.geoserver.logging.LoggingStartupContextListener.contextInitialized(LoggingStartupContextListener.java:66)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
2015-11-18 08:52:37.492::WARN: failed ContextHandlerCollection@anonymised.com
2015-11-18 08:52:37.495::INFO: Opened /home/ben/tmp/geoserver/geoserver-2.8-SNAPSHOT/logs/2015_11_17.request.log
2015-11-18 08:52:37.495::WARN: failed HandlerCollection@anonymised.com
2015-11-18 08:52:37.496::WARN: Error starting handlers
2015-11-18 08:52:37.504::INFO: Started SelectChannelConnector@anonymised.com:8080
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
