Geoserver blows up looking for default geometry, even if data has no geometry.
Key: GEOS-1020
URL: http://jira.codehaus.org/browse/GEOS-1020
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.5.0-RC4
Environment: Created a datastroe using "geometryless" JDBCDataStore.
Reporter: Rob Atkinson
Assigned To: Andrea Aime
Fix For: 1.5.0
GetFeature, with no spatial operators, blows up for no good reason if the feature type has no default geomtery.
Caused by: java.io.IOException: Feature type: topp:measuringdevice does not have a default geometry
at org.vfny.geoserver.global.FeatureTypeInfo.getNativeCRS(FeatureTypeInfo.java:656)
at org.geoserver.wfs.GetFeature.run(GetFeature.java:244)
finding CRS and calculating bounding boxes should be skipped for feature types without geometry.
(geometryless works on gt trunk - and can be configured easily using the GUI now. Defaults work with a local postgres install.)
