Add an option to generate formatted XML, or generate as formatted by default
Key: GEOS-1024
URL: http://jira.codehaus.org/browse/GEOS-1024
Project: GeoServer
Issue Type: Task
Components: WFS
Affects Versions: 1.6.0-alpha2
Reporter: Andrea Aime
Assigned To: Justin Deoliveira
Fix For: 1.6.0-beta1
GML generation results in a single line file. Would be nice to have it formatted, at least for developers and users alike.
It may be a configuration option, or we may default to formatted output by default (if we use tabs it should not make the file grow much, no?)
