Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-104
Here is an overview of the issue:
Key: GEOS-104
Summary: GetFeature namespaces and schemas location
Type: Bug
Status: Open
Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Assignee: Chris Holmes
Reporter: Miguel Ángel Esbrí Palomares
Created: Thu, 4 Mar 2004 7:53 AM
Updated: Thu, 4 Mar 2004 7:53 AM
Environment: windows xp os, geoserver 1.1.1
Description:
Oh, I see what you're saying. Sorry for being dense. I need to think
about it. You are correct - I remember not quite finishing all the
support for multiple namespaces. If you could file this as a bug on the
jira task tracker at
http://jira.codehaus.org/secure/BrowseProject.jspa?id=10311 that would be
super helpful. Put the fix version of 1.2.0 and I'll be sure to hit it
before the next release (my time is tight right now or I'd do it right
away - and if you feel like digging through the code and contributing a
fix that would be great).
thanks,
Chris
On Mon, 1 Mar 2004, Miguel Ángel Esbrí wrote:
Chris Holmes wrote:
>What does the response to
>>>http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=ntadfhwa_uza:ntadfhwa_uza,fire:fire*
>>>look like? It shouldn't need two imports there, as that
>DescribeFeatureType response should actually just be two different imports
>of the namespaces, which the validator would then follow and get the
>actual schemas. So basically geoserver puts the two imports in that
>describe feature type statement.
>If you could email me the full response to the GetFeature request, as well
>as to the describe request with both and the describe requests with one
>each, along with the catalog.xml, info.xml and schema.xml files if you
>used them I can try to diagnose the problem. GeoServer has been tested
>through the CITE conformance tests for this, so it should work, it's
>likely an error with configuration.
>Chris
>On Fri, 27 Feb 2004, Miguel Ángel Esbrí wrote:
>>>When I write the following request -->
>>http://myserver:8080/geoserver/wfs?request=GetFeature&typename=ntadfhwa_uza:ntadfhwa_uza,fire:fire
>>I get the following:
>><?xml version="1.0" encoding="UTF-8" ?>
>>- <#> <wfs:FeatureCollection xmlns:wfs="*http://www.opengis.net/wfs*"
>>xmlns:fire="*http://picasso.dlsi.uji.es/schemas/oklahoma/fire*"
>>xmlns:gml="*http://www.opengis.net/gml*"
>>xmlns:ntadfhwa_uza="*http://picasso.dlsi.uji.es/schemas/oklahoma/ntadfhwa_uza*"
>>xmlns:xsi="*http://www.w3.org/2001/XMLSchema-instance*"
>>xsi:schemaLocation="*http://picasso.dlsi.uji.es/schemas/oklahoma/fire
>>http://localhost:8080/geoserver/data/capabilities/wfs/1.0.0/WFS-basic.xsd*">
>>- <#> <gml:boundedBy>
>>- <#> <gml:Box srsName="*http://www.opengis.net/gml/srs/epsg.xml#13869*">
>> <gml:coordinates decimal="*.*" cs="*,*" ts="">-98.53723199,34.5322885
>>-98.53723199,36.59758438 -94.43181798,36.59758438
>>-94.43181798,34.5322885</gml:coordinates>
>> </gml:Box>
>> </gml:boundedBy>
>>So, when I try to validate de response with a xml validator I get the
>>following errors:
>> * ERROR at line 2: cvc-complex-type.2.4.a: Invalid content was found
>> starting with element 'fire:fire'. One of
>> '{"http://www.opengis.net/gml":\_Feature\}' is expected.
>>I think the bug is in this line:
>>because *ntadfhwa_uza and **fire prefixes belong to distinct namespaces
>>(**http://picasso.dlsi.uji.es/schemas/oklahoma/fire and
>>**http://picasso.dlsi.uji.es/schemas/oklahoma/**ntadfhwa_uza**and
>>**respectively) , so geoserver should generate something similar to this:
>>*xsi:schemaLocation="*http://picasso.dlsi.uji.es/schemas/oklahoma/fire
>>http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=fire:fire
>>http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=**ntadfhwa_uza:ntadfhwa_uza"\*
>>Any suggestion???
>When I make the following request I get the following, which is correct:
Request:
Response:
<?xml version="1.0" encoding="ISO-8859-1" ?>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified" attributeFormDefault="unqualified"
version="1.0">
<xs:import
namespace="http://picasso.dlsi.uji.es/schemas/oklahoma/ntadfhwa_uza"
schemaLocation="http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=ntadfhwa_uza:ntadfhwa_uza"
<xs:import
namespace="http://picasso.dlsi.uji.es/schemas/oklahoma/fire"
schemaLocation="http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=fire:fire"
</xs:schema>So, as you can see, each import has its own namespace uri and the schema
location.But when I make this request:
http://localhost:8080/geoserver/wfs/GetFeature?typeName=ntadfhwa_uza:ntadfhwa_uza,fire:fire
I get the following response (attached to this email is the complete
response):<?xml version="1.0" encoding="UTF-8" ?>
- <wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs"
xmlns:fire="http://picasso.dlsi.uji.es/schemas/oklahoma/fire"
xmlns:gml="http://www.opengis.net/gml"
xmlns:ntadfhwa_uza="http://picasso.dlsi.uji.es/schemas/oklahoma/ntadfhwa_uza"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://picasso.dlsi.uji.es/schemas/oklahoma/fire
http://localhost:8080/geoserver/data/capabilities/wfs/1.0.0/WFS-basic.xsd">
- <gml:boundedBy>
- <gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#13869">
<gml:coordinates decimal="." cs="," ts="">-98.53723199,34.5322885
</gml:Box>
</gml:boundedBy>
- <gml:featureMember>So, as you can see, the xml is saying that you can find the schema
through
and that it has the namespace uri
http://picasso.dlsi.uji.es/schemas/oklahoma/fire.But that isn't true, because the correct would be this:
http://picasso.dlsi.uji.es/schemas/oklahoma/ntadfhwa_uza:ntadfhwa_uza
http://localhost:8080/geoserver/wfs/DescribeFeatureType?typeName=ntadfhwa_uza:ntadfhwa_uza"because they belong to two different namespace
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
