[Geoserver-devel] [jira] Created: (GEOS-1049) [WFS-T] String length ignored in DescribeFeatureType for features stored in PostGIS?
                 Key: GEOS-1049
                 URL: http://jira.codehaus.org/browse/GEOS-1049
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.4.0
         Environment: PostgreSQL 8.2.3, PostGIS 1.2.1
Data has been imported from a shapefile, using shp2pgsql
            Reporter: Frank Steggink
            Assignee: Andrea Aime
I've imported a shapefile into a PostGIS database. Here's a part of the description:
   Column | Type | Modifiers
gid | integer | not null default nextval('test_gid_seq'::regclass)
gm_code | character varying(16) |
gm_naam | character varying(30) |
postcode | character varying(11) |
dek_perc | bigint |
opp_tot | integer |
(omitted)
the_geom | geometry |
(My excuses for the bad formatting, if this occurs. I hope it will be readable enough.)
As you can see, there are a few strings, which have a maximum length.
Now, when I do a DescribeFeatureType on this feature (called pgtest:test), I'm gettting the following response:
<?xml version="1.0" encoding="UTF-8"?><xs:schema targetNamespace="http://www.example.org/pgtest&quot; xmlns:pgtest="http://www.example.org/pgtest&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:xs="http://www.w3.org/2001/XMLSchema&quot; elementFormDefault="qualified" attributeFormDefault="unqualified" version="1.0"><xs:import namespace="http://www.opengis.net/gml&quot; schemaLocation="http://127.0.0.1:8080/geoserver/schemas/gml/2.1.2/feature.xsd&quot;/&gt;&lt;xs:complexType xmlns:xs="http://www.w3.org/2001/XMLSchema&quot; name="test_Type">
<xs:complexContent>
<xs:extension base="gml:AbstractFeatureType">
<xs:sequence>
<xs:element name="gm_code" minOccurs="0" nillable="true">
<xs:simpleType>
<xs:restriction base="xs:string">
<xs:maxLength value="2147483647"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="gm_naam" minOccurs="0" nillable="true">
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="postcode" minOccurs="0" nillable="true">
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="dek_perc" minOccurs="0" nillable="true" type="xs:long"/>
<xs:element name="opp_tot" minOccurs="0" nillable="true" type="xs:int"/>
<!-- Again, omitted a couple of properties -->
<xs:element name="the_geom" minOccurs="0" nillable="true" type="gml:MultiPolygonPropertyType"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:element name='test' type='pgtest:test_Type' substitutionGroup='gml:_Feature'/></xs:schema>
As you can see, the maxLength of the string properties (gm_code, gm_naam, postcode) are quite different from the values according to PostGIS. Is this a known issue? I couldn't find any information on this in the issue tracker, and I had problems while searching this mailing list (but couldn't find a hint either).
If I add the original shapefile as the datasource, the maxLength attributes contain the correct length.
This isn't a problem while retrieving features, but it is for posting. I have entered a string which is too long (I didn't think about the maxLength restriction), and Geoserver returned the following exception: <wfs:Status><wfs:FAILED /></wfs:Status><wfs:Message>Some sort of database connection error: ERROR: value too long for type character varying(16)</wfs:Message>. Our software is able to cap the length of the entered string, based on the maxLength returned by DescribeFeatureType.
