Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-105
Here is an overview of the issue:
Key: GEOS-105
Summary: server doesn't return the fetched property and all the mandatories properties defined in the schema
Type: Bug
Status: Open
Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Versions:
1.2-beta
Assignee: Chris Holmes
Reporter: Miguel Ángel Esbrí Palomares
Created: Thu, 4 Mar 2004 8:00 AM
Updated: Thu, 4 Mar 2004 8:00 AM
Environment: windows xp os, geoserver 1.1.1
Description:
When I make this request:
I get only the features with the specified property name (which is an
optional property), but the wfs specification says that the server must
in the schema.The same occurs when I make the request with a mandatory property (I get
only the specified property).
Yeah, our solution to that requirement for WFS is a bit hacky. In 1.2
it'll be done with schema.xml files, for 1.1 the information is
duplicated. Basically what you need to do is set the attributes that are
mandatory in the info.xml file <attributes><attribute name="gid"
mandatory="true"></attributes> I think is the form, check the
advanced.htm in the user docs, and I think one of the sample info.xml
files also has it. Note that the non-mandatory ones you will also have to
list, or they will not show up at all (this is how you 'hide' attributes).
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
