[Geoserver-devel] [jira] Created: (GEOS-1055) Base map seems to use layer's default style instead of using the ones defined along it
                 Key: GEOS-1055
                 URL: http://jira.codehaus.org/browse/GEOS-1055
             Project: GeoServer
          Issue Type: Improvement
          Components: WMS
    Affects Versions: 1.5.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Critical
According to one of our users:
The first issue is that the rendering under v1.5.0 is all messed up. I'm
using the layer grouping functionality to create a virtual basemap layer but
v1.5.0 doesn't seem to handle it properly. It looks like it might be
rendering the layers using the default style associated with the feature
type rather than the one specified with the virtual layer.
