[Geoserver-devel] [jira] Created: (GEOS-1062) Improve error reporting for Filters with wrong attribute names
                 Key: GEOS-1062
                 URL: http://jira.codehaus.org/browse/GEOS-1062
             Project: GeoServer
          Issue Type: Improvement
    Affects Versions: 1.5.0
            Reporter: Chris Holmes
            Assignee: Andrea Aime
             Fix For: 1.5.x, 1.6.0
If one puts in the wrong attributes in to a CQL error query things go very wrong. First you get a translator error, which always means some sort of nested problem.
After turning verbose exceptions on you get a bunch of junk and then:
Caused by: java.lang.RuntimeException: Exception occurred while computing reprojected bounds
  at org.geotools.data.crs.ReprojectFeatureResults.getBounds(ReprojectFeatureResults.java:183)
  at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:404)
  at o
rg.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:610)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:292)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:125)
  ... 42 more
Caused by: java.lang.ClassCastException: org.geotools.filter.AttributeExpressionImpl cannot be cast to org.geotools.filter.Filter
  at org.geotools.filter.visitor.PostPreProcessFilterSplittingVisitor.getFilterPre(PostPreProcessFilterSplittingVisitor.java:125)
  at org.geotools.data.jdbc.DefaultSQLBuilder.splitFilter(DefaultSQLBuilder.java:153)
  at org.geotools.data.jdbc.DefaultSQLBuilder.getPreQueryFilter(DefaultSQLBuilder.java:136)
  at org.geotools.data.jdbc.JDBC1DataStore.getFeatureReader(JDBC1DataStore.java:608)
  at org.geotools.data.jdbc.JDBCFeatureCollection.reader(JDBCFeatureCollection.java:78)
  at org.geotools.data.crs.ReprojectFeatureResults.reader(ReprojectFeatureResults.java:155)
  at org.geotools.data.crs.ReprojectFeatureResults.getBounds(ReprojectFeatureResults.java:175)
  ... 47 more
We should be able to check much earlier if the attribute asked for is wrong. I believe we used to have this in some form? I think the old filter splitter let you know.
Hi Saul,
Congrats!! You may find that I already commit some of the work, like putting the context listener in web.xml. Sorry if I stepped on your toes :).
-Justin
                 Key: GEOS-1062
             Project: GeoServer
  at o
  ... 42 more
  ... 47 more
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
